Sony Insider Forums
marcnet
Himdlister
Okay, I know someone has already done a listing program. So I decided to continue and finish the one I was working on. And this is its first release. Im in the process of starting a nice guide with pretty pictures and everything. However, until that is finished, here is a short guide in plain text:
1) Start the program
2) Connect HIMD device with a HIMD disc to PC. Make sure SonicStage isnt running and press "Get Tracks"
3) Select how you would like to order the tracks in the output listing file. The top sorting option has highest priority, the second has the next priority and the last has the lowest priority.
4) Select how each track in the listing file will be presented. You have up 21 components to do this. Remeber that carriage returns are NOT placed in the listing file by default, so it might be a good idea to use <CRLF> or <CR> as you last option if you want carriage returns.
4b) If you previously have saved a format configuration (see step 6) then press "load format" and select the .hfc file.
5) If you select a track in the track list then the example at the bottom of HIMDLister will show you the selected track in the selected format.
6) If you wish, you can save the format configuration for re-loading in the future. The format of these configuration (.hfc) files are pure binary, so dont go an edit them. If you do then dont complain my program crashes!
7) Press "Export List" to create the list fle.
Ive missed some things out, such as the Amount/Custom fields and the "case sensative" options. I hope the functionality of those options is obvious. I will include them in my fancy guide that I will get round to writing at some point.
You want to download and try it? Well here are some links.
A message board has been created on my site for the program:
http://www.marcnetsystem.co.uk/himdlister/
And the program itself (version 0.04) is here:
http://www.marcnetsystem.co.uk/himdlister004.zip
Share this post
Marcnet,
I have downloaded your program, but it seems to reconize only few of the tracks present in the disk. Any Idea?
Cheers
Share this post
Marcnet,
Cheers
Here the same problem, only 72 tracks are recognised but there are over 200 tracks on the disc.
p.s. this program: http://forums.minidisc.org/index.php?showtopic=7944 does a better job and recognises all tracks.
Share this post
Marcnet,
Cheers
I've tried it and have the same problem as well.
Share this post
Okay, im working on it. For some reason I cannot reproduce this problem with my own HIMD collection so ive asked someone to email me the HMA files (except the really really big one) from a HIMD disc that causes this problem. I was wondering if one or more other people could do the same..... PM me if your willing to help
Also, any other ideas about how I could improve the progam?
EDIT:
There. Ive worked on it. Version 0.03 is available here:
http://www.marcnetsystem.co.uk/himdlister003.zip
Share this post
EDIT:
Problem solved here!
Share this post
Mmm, version 0.03 doesn't seem to work at all for me (Windows 2000) - I've got a very full 1GB Hi-SP disk - nearly 8 hours worth, and it just sits there and hangs...
Also, sorry to be a bit picky, Marc, but it should be "Case Sensitive", rather than Sensative...
Share this post
I am at work now. I'll test the new version tonight at home.
Sorry, I have to delay the test as yesterday evening I had to reformat my home PC hard disk.
Share this post
Hi,
The himdlister is great! biggrin.gif Multiple options are super, but I would like to see the option of just listing the groups (albums) on a HiMD ONCE, so I can paste that list into my labelling program. If I select 'group' from the first format dropdown box, I get a listing with x times the Group name (where x is the number of tracks in a group).
Is it possible to create such an option?
Thanks!
wink.gif elsen029
Share this post
Yup. I can do that for version 0.04
And you only needed to ask once. I do read this forum as often as I read my own web site message boards. Thanks. smile.gif
Hi,
Thanks!
wink.gif  elsen029
Share this post
Sorry, but I found a little bug. When a track is longer than 1 hour (whole CD's as 1 track) the calculation of the track-durating goes wrong. This goes ALWAYS wrong. Some examples:
1h:14m:3614s
1h:15m:3630s
1h:17m:3611s
1h:17m:3641s
1h:17m:3648s
1h:19m:3636s
1h:19m:3642s
1h:19m:3642s
1h:20m:3651s
Also most of the durations of a track in Hi-MD-lister are 1 second more that SonicStage says. This is not so serious but has probably something to do with rounding the seconds.
Share this post
Dont be sorry smile.gif Ill get it fixed in 0.04
The rounding issue.... I dont know - ill have to look in more detail... But, for example - 3 minutes 14 seconds 300 milliseconds ... I call that 3 minutes 15 seconds and sonicstage may call it 3 minutes 14 seconds..... which would you prefer?
1h:14m:3614s
1h:15m:3630s
1h:17m:3611s
1h:17m:3641s
1h:17m:3648s
1h:19m:3636s
1h:19m:3642s
1h:19m:3642s
1h:20m:3651s
Also most of the durations of a track in Hi-MD-lister are 1 second more that SonicStage sais. This is not so serious but has probably something to do with rounding the seconds.
Share this post
According to a commonly used convention (at least in physics, my work), up to 499 milliseconds one should round down, from 500 milliseconds up one should round up. smile.gif
Share this post
That is what I would say and probably what SonicStage does because a second exists of 1000 milliseconds.
Share this post
Today I created some testscript in PHP that uses Hi-MD Lister exported textfile as an input to nicely represent what is on the Hi-MD-disc.
The following example is the current contents of my 1 GB disc that I use daily when travelling by bus and train:
http://www.mdcenter.nl/test/himdlister/
Share this post
That's pretty slick. Import that information into a MySQL DB and you've just created a simple cataloging program. Get some barcodes and you've got yourself a media library... Neat.
Share this post
Marcnet -
I downloaded .03 and found the tracks, creating a format. The file was saved as a .txt successfully but I cannot open it to see, print or database it. I have tried with Notepad, Wordpad and Wordperfect 11 with several .txt optiions. What should I try?
Share this post
Sounds like a great program. But I have one, maybe stupid, question. Does it works with a normal NetMD (JE780)? I couldn't find it anywhere and I can't test it my self at the moment.
Share this post
Sadly no, It reads one of the *.hma files on the Hi-MD disc which contains the structure of the audio-directory in text-format. Sadly no such files are on a NetMD disc. Also a NetMD disc isn't available via Windows-explorer as a file that you can access.
Share this post
New version 0.04.
Download:
Changes:
* Track lengths calculation improved.
* Added "Track length rounding" option. If a track length has a fractional part that is over 0.500 seconds then the track length is added by one second. SonicStage dosn't seem to do this so turn this option off for the track lengths to match what SonicStage does.
* Corrected spelling of "Sensitive"
* New group listing mode. Only track groups are listed in this mode. Tracks that are not in a group are not included in the group length calculations.
Share this post
New version 0.04.
Download:
Changes:
Tested it: bug with tracks longer than an hour fixed!
Added a link to your project on:
http://www.mdcenter.nl/forums/viewtopic.php?t=807
Share this post
Can I ask you a question?
In my HiMD-Xtract I didn't find out how you can see that a track has no name yet (an analog recording for instance). So when an unnamed track is put in front of other tracks, tracknames will shift and end up with the wrong track.
Apparently your program successfully identifies unnamed tracks.
Edit: on second thought, I think it doesn't, but if it does...
Would you be so kind as to tell me where that information is stored, so I can fix my program?
Thanx,
fish
Edited by fishstyc
Share this post
Easy as eating pie:
Starting at position 0x8050 you have all sorts of information for each track. Each entry is 80 bytes big.
Offset 8 and 9 (16 bit value) describe the position of the track name
Offset 10 and 11 (16 bit value) describe the position of the artist name
Offset 12 and 13 (16 bit value) describe the position of the album name
If any tracks have "00 00" for any of these fields then that track does not contain that attribute.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
