Sony Insider Forums
xispe
GYM | Network Walkman BROWSER-PLAYER-EXTRACTOR
One thing that i would like to add that whenever u save tracks.It save in mp3 128kpbs(default) irrespective in which format & in which bit rate u have transffered ur files in ur network walkman.I see no setting to change the bitrate of saving the tracks.I think there should be more flexibilty for this thing
please note this xispe
GYM doesn't do any kind of bit rate conversion. After saving if you get 128 kbps files means that you have 128 kbps files in the player.
There shall be no setting to transcode to a different bitrate, the tracks shall be copied as is.
Thanks :ol_smile:
Share this post
The encoded files in the player don't have IdTags, SS and MP3FM cuts them out. :(
I'm considering the possibility of recreating some of the Id3Tags by using the Title, artist, Album, Genre information that are associated with the track.
Wow... that's odd! I'll try to check that ... but the files are with the same bitrate / length...
Thanks for using GYM! :ol_cool:
I'm very sorry but I've mistaken a bit. :ol_angry: .. 20% looks like enormous. And it is! I surely compared two different files. I verified and the difference is about some ko max only! (Surely tags cut..).
So no problem with that and forget it!
Share this post
Thanks  :ol_smile:
Thanks god :ol_dead:
If it wasn't you create the fastest encoder on the world :ol_lol:
I tried GYM on usb 1 on my work, init is longer 3mn with my HD5 30Go.
10 s on USB2.
I cant imagine creating the keys on usb1
Edited by Vovo
Share this post
GYM at your work, GYM at home, GYM everywere!
Everybody is working out. Let's exercise! Healthy people! :D
Share this post
Guest Stuge
Your computer has USB 2.0 ? or 1.1 ?
It seems that it is taking too long to get the tracks off the player...
How long are the tracks ?
What are your computer specifications ?
While reading the source track GYM decodes the track using the correct cypher keys. This process can be intensive, depending mostly on your computer specifications.
My computer has USB 2.0
2.I have tested track of around 3-4minutes
3.(i).CPU.Pentium 4(2.0ghz)
(ii).Ram.512mb.
(iii). Western Digital Hard Disk(5200rpm)
Thanx........
Share this post
What does it means GYM ?
Is it for gymnastic ? Do you want everyboby Healthy ?
With GYM my mind is going better, it's the first step :ol_lol:
Share this post
Guest Stuge
I saved those tracks which were transferred from Sonic stage to e505 at atrac 64kpbs & about mp3 they were all tranferred at 192kpbs thats why i was telling u that it converts files in 128kpbs & i was amazed to see that
Note: For testing i chose 5 tracks at 64kpbs(atrac) & 5tracks at 192kpbs(mp3).Total of 10 tracks were tested...
Edited by Stuge
Share this post
'G'rab 'Y'our 'M'usic find it, now i can sleep !
Share this post
Any plans to add unicode support to this neat piece of software? My Japanese titles are all jumbled within the program. :ol_sad:
Share this post
Hello Xispe
After 3 days of intensives tests, i really love GYM !!!
Now when i'm at work i listen my music with GYM, the browser is great
(no more little lcd display) and the shuffle is easy, without stupid playlists.
And now some suggestions (only suggestions)
- Shuffle mode : it will be nice to sort the track list with the shuffle order
and play all sequentially.
- Player : a pause, volume control or simply to launch winamp,
but i like the idea of the internal player (autonomous use)
- Browser : The track# (need to be calculate, i think), ATRAC/MP3, bitrate, size...
- Put the focus on the playing track in the browser.
- Perhaps it's possible to preload the next track to avoid silences.
- Saving atrac files on the pc, just a simple copy but with the good file name,
after they could be convert with HIMDrender.
- Recreating tags for mp3 with the filename (actually i do it with tag&rename)
- An icon for GYM.exe
It's only feedback, there's no orders in my suggestions,
you can do what you want with these ideas.
Thanks a lot (again) for your work. :ol_lol:
Edited by Vovo
Share this post
First i 'd like to thank you for this brilliant software.
I just thought, what about adding support to those 20Pxx directories
and retrieve the jpeg files in the GYM GUI ???
it would be just awesome !!
thanks
Edited by funkycochise
Share this post
Can I just say excellent work on this app - I've been waiting for something like this since I bought my NW-HD5.
My sincere thanks for helping me escape from SS.
I was going to try writing something, but you have saved me time and effort here - cheers!
As far as I can see, this app needs to be pushed in the following direction:
1. Integrate the mp3manager functionality into the program. I know some progress was made understanding how this working for the HD3. I think there are differences for the HD5 though. This link may help
http://www.livejournal.com/users/waider/41...=804837#t804837
2. Playlists? Wouldn't that be GREAT?!!! I have none on my player, since I refuse to use SS!
If you need a bit of cash, I will definitely contribute via Paypal!
Good luck my friend
N
Share this post
Doesn't play my files either at home on XP or at work on 2000. Please find debug code from my work machine. Any ideas?
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Lister.Classes.PlayQueue.Play()
   at Lister.MainForm.pb_Play_Pause_MouseDown(Object sender, MouseEventArgs e)
   at System.Windows.Forms.Control.OnMouseDown(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/winnt/microsoft.net/framework/v1.1.4322/mscorlib.dll
GYM
    Assembly Version: 1.0.2143.22909
    Win32 Version: 1.0.2143.22909
    CodeBase: file:///E:/GYM1.0/GYM.exe
    CodeBase: file:///c:/winnt/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
    CodeBase: file:///c:/winnt/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
    CodeBase: file:///c:/winnt/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
    CodeBase: file:///c:/winnt/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
CSSound
    Assembly Version: 1.0.2143.22689
    Win32 Version: 1.0.2143.22689
    CodeBase: file:///E:/GYM1.0/CSSound.DLL
Share this post
In this weekend i'll try to produce a webpage for the software, with a looooong wishlist section, where I will put all your comments / wishes.
I also plan to release a new version to fix some bugs I detected and others you detected.
And of course add a Paypal Donate link for those interested! :D
THanks! ;)
Share this post
THanks! ;)
Great
GYM deserve its own website,
and you, encouragements...
If you need help for translate GYM in French, testing, etc...
Bye Xispe
Share this post
Is there a good chance that your program will be able to aslo upload mp3s and possibly without conversion?
i'm trying to find a website, forum, or even a straight download link to the Mp3file Manager program everyone here is talking about. could anyone post it
Share this post
Try this
MP3FileManager
Bye
Edited by Vovo
Share this post
Try what I did witht he VAIO Pocket - install the progrma in your computer, then go to the folder it was installed in and copy it to your player.
Share this post
Guest Stuge
I forgot to mention that i have hd3 walkman. Sony filemanager doesn't seem to support it. If you think or know otherwise let me know if i should still install it and use with hd3
Who told u that mp3 filemanager is not suppoted by nw-hd3..????????????
Share this post
The list of the supported players is posted on the download page and there is no mention of hd3.
Driver & MP3 File Manager Ver.2.0 Installer for the Network Walkman NW-E103/E105/E107/E403/E405/E407/E503/E505/E507
but i will install and see what happens.
Share this post
I just tried instaling mp3 file manager and it can't find a player. Any ideas to make it recognize it. I turned off ss and left the player connected.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
