Sony Insider Forums
greenmachine
How to build a Stereo Microphone and Battery Box
Hi,
I'm totally new to live recording and even more to all the technical details here. Since I have a minidisc I thought to give this DIY a go. I think it's clear enough for even a total beginner like me. So thanks for this DIY.
I just have one question about matching the microphone capsules.
How do I do this? Do you mean by matching that they should have sequential numbers?
Thanks
Share this post
Matching is the process of finding two (or more) capsules that perform (close to) identically in order to keep channel differences at a minimum. It can be done in different ways. The most simple yet effective is propably to wire two capsules, hold them as close together as possible, use a loudspeaker with random noise or music or different individual frequencies as the sound source, connect the mics to the recorder, set it to rec pause (with appropriate manual levels set) and observe the meters while moving back and forth to the loudspeaker (or fix them at a certain distance and adjust the loudspeaker's volume). If they read exactly the same in the upper range, you have found two matching capsules. If they don't, try again with different capsules. If you don't have more than two capsules available, you can skip matching and hope for the best.
Good luck.
Share this post
would it make a difference, using polarized vs nonpolarized caps? i know in speakers you have to use nonpolarized for the crossover to the tweeters, but would it make a difference in this?
thanks
Share this post
Electrolytic (polarized) caps have an advantage in size and price, while other materials might be more durable. They should perform nicely for at least a few decades though. The negligibly small alternating voltage from the mics won't damage polarized capacitors.
Share this post
Just saw this thread. Excellent! I really like the altoids tin case. I don't mind the extra bulk. I am going to have to try this!
Share this post
I want to thank greenmachine again for this diy. I can't believe the quality of recording that can be made with this! It has given me inspiration to take on some other electronics projects. I've got lots of books from the library, and am soldering something up almost every night.
Share this post
We need to thank those who invented the electret technology. Also those who build, constantly improve them and make them available to the public at very affordable prices. I think these little panasonics are a milestone in recording quality if you know their limitations (i can't think of any other than somewhat high self-noise at the moment) and how to use them effectively.
Share this post
Is there an easy way to add a light that shows the existing battery power? I have a commercial 9v unit and never know whether the battery is still good or not. I don't find out my battery's dead until I hear my crappy recording. I'm thinking of building this DIY unit and that would be a handy feature. Thanks!
Share this post
I'd rather use a multimeter or any other externel battery tester, but you can try this simple circuit. You'll need a pushbutton, two resistors and a red LED (2V). At 9V the LED will glow bright enough to be easily recognizable, at 7-8V pretty dim and from approximately 6V and below there's no indication anymore. At that point it's about time to replace the battery. Always disconnect either the microphones or the battery after use to avoid unnecessary drain. Don't use a permanent switch, which can be accidentally left in 'on' position to avoid unwanted current drain by the test circuit. If you want to use blue, white, green or any other 3V LED, you'll need different values for the resistors.
Here's an exemplary schematic:
[attachmentid=1437]
Edited by greenmachine
Share this post
Here's a new setup I tried Saturday. It is a set of diy mics from the tutorial. I mounted them in an aluminum tube with hot melt glue, then put some heat shrink over them.
[attachmentid=1454]
Then I cut some rings out of pvc, drilled some holes in them to thread elastic cord through, and mounted the mics in them as a shockmount. I then used my soldering "helping hands" and a drum clamp to rig it all to a mic stand.
[attachmentid=1455]
[attachmentid=1456]
I added a song to my album from Saturday nite. I think it turned out pretty good. This diy stuff is addicting!!!
Edited by woulfer
Share this post
How do you like the sound without a separator (your head) in between? From own experiments, i think it sounds a little lifeless/flat, without real dimension/depth. You could also try to experiment with a jecklin disk, dummy head or any other kind of artificial baffle. Thanks for sharing.
Share this post
I had planned to try to make a jecklin disc, but just ran out of time. Through speakers, I think is sounds fine. I have not yet heard it through headphones. I think I will notice the difference a lot more then. I'll report back tonight and let you know. I posted a song in the gallery, if anyone wants to check it out. I'd appreciate any comments you may have.
I really like the "battery test" circuit. It would be a nice feature for when your running out the door and don't have your multimeter handy. I really appreciate you sharing your knowledge with us!
Share this post
GM,
thanks for the DIY. I just bought 4 61b's for $9 + shipping and need to get the other stuff somewhere.
These have tabs, and I believe they are there to solder to to keep the heat down. Being a rather novice, do you think I'll do any damage with my 25w iron. I doubt I'll be soldering to those tiny tabs. I've soldered to my AIWA's and did no damage and the pellets were too hot to touch!!
What d'ya think?
I've got some small heat sinks that fell off my old sound card, so I'll clamp the pellets to those to help.
Edited by RockyDisc
Share this post
The more heat you apply, the shorter you have to keep the soldering time in order not to damage it. Passive cooling should lower the risk somewhat. I've also (most of the time successfully) done it with a 25W iron before i got a better suited one. The trick is to work quickly. If you don't succeed instantly, let it cool down then try again.
Share this post
I squeeze my SoundPro BMC-2 into these. But it's a very tight fit and they have a soft housing. Greenmachine's mics might be just a tiny bit too big in diameter.
http://www.bhphotovideo.com/bnh/controller...oughType=search
Take a look at these, too:
http://www.bhphotovideo.com/bnh/controller...t.y=8&Submit=Go
You can wire a mic to the one on the bottom, with the wire running between the body of the clip and its little holder.
Share this post
well I made the mic connections. I can't tell if my solder job got the cap too hot causing damage or not. How would you tell
Also I couldn't find small dia shielded cable so I settled for a radio shack special. A 6' single core with shielding sold with alligator clips as a test cable. It is almost as thick as the 6mm mics so the soldering was that much harder to see. I'm not sure if I soldered the ground where it is touching the case, but I do hear crackling when I bend the cable so I don't know where I stand on that one. Anyone know for sure what would cause the crackling when the cable is flexed?
Share this post
well my first mic is rather ugly and the cabling is way too stiff, I'd say its 5mm judging from the 6mm mics. And my radio shack mini-jacks are huge and clunky. Anyway I can't find shielded cabling. Would the unshielded give me problems in a theatre setting where there shouldn't be much EM interference?
The wires for something like cheap earbuds would be just right although they may develop continuity problems.
Share this post
A shielded cable just blocks electro magnetic fields / radio frequencies somewhat better. If you stay away from EM/RF emitters, it doesn't really make a difference. Use whatever is available. Your choice of mic capsules and mic placement will make the big difference in sound quality in the end, not the cable.
Share this post
Sounds great, I figured I'd be safe in my recording environment but I'm going to try again with the cheapo (but small) wires.
Thanks for replies, I'll post again when I get these done.
Share this post
Panasonic WM-61A mic capsules were $1.89 a piece. I found some cheap headphones for a buck that I cut off the phones to use a cable. Some hot melt glue, solder, and heatshrink, and there's the mics.
For the battery box, the stereo jack and the battery are the most expensive. I'd bet you can do this project for $15 or less, depending on whether you already own some of the tools necessary (i.e. soldering iron, solder, glue gun, etc.)
Share this post
Create an account
Register a new account
Sign in
Sign In Now
