Sony Insider Forums
Hi-MD Music Transfer for Macintosh v. 2.0
Sony has officially released an updated version of the Hi-MD Music Transfer application for Mac OS X. There are some amazing improvements for file transfer that applies to MZ-RH1/RH10/RH910/RH710 owners.+++
Sony offers Hi-MD Music Transfer for Mac Ver.2.0 for owners of the following Hi-MD Walkman models:
  • MZ-RH1/RH10/RH910/RH710
New features of Hi-MD Music Transfer for Mac Ver.2.0:
* Applicable only to the stated Hi-MD Walkman model
MZ-RH1:
  1. User can import audio data recorded in Linear PCM, Hi-SP or Hi-LP mode on the Macintosh-compatible Hi-MD Walkman to a Macintosh computer after converting to WAV format audio data.*1
  2. User can download WAV*2 or MP3 format audio data from a Macintosh computer to a Hi-MD Walkman.*3
  3. User can change a track or group title in a Hi-MD disc, and change the order of tracks or groups.
  4. User can erase the tracks or groups in a Hi-MD disc.
MZ-RH10/MZ-RH910/MZ-RH710:
  1. User can download MP3 format audio data from a Macintosh computer to a Hi-MD Walkman.*3
  2. User can change a track or group title in a Hi-MD disc, and change the order of tracks or groups.
  3. User can erase the tracks or groups in a Hi-MD disc.
*1 - An audio data transferred using SonicStage or MD Simple Burner and an audio data downloaded from this software cannot be imported.
*2 - WAV format audio data is downloaded after converting to Linear PCM.
*3 - If an audio data downloaded from this software is used on SonicStage, some functions such as transfer times or CD burning, etc are limited.
Download (*.dmg): http://forums.minidisc.org/downloads/details.php?file=95
Download (*.zip): http://forums.minidisc.org/downloads/details.php?file=98
Download (Sony): http://www.css.ap.sony.com/Consumer/templa...=Personal+Audio
Share this post
It could be interesting to test it against 1st gen. HiMD not listed in the description (out of curiosity, I don't own a Mac myself)
Share this post
as the program only transfers MP3 and 1st gen can't play MP3 nor convert it on the fly and only Mac-compatible machines are able to upload to mac, I really doubt that connecting a 1st gen HiMD to mac and opening HiMD music transfer will do anything remarkably interesting :P but if you really need proof of this, I'll try it as soon as I get near my NH900 (in my desk at work at the moment and I'm working from home right now)
Share this post
Good point, I should have read better.
Share this post
Wow! They even let RH10 users do something with Mac! I downloaded, installed (first the installer requires to de-install the previous Hi-MD Music Transfer program which was installed "just in case it will work with RH10").
This is what we have:
G4 with MacOS 10.4.7
MZ-RH10
The first impression is disappointing:
No help, no system requirements, not even software version indicated. The software is made with no love.
1st try Hi-MD 1Gb inserted
In good traditions of the software making IT DOESN'T EVEN START. At all. Well actually it does but immediately quits unexpectedly.
2nd try RH10 is not attached at all
Software starts and shows its laconic interface. Looks quite a bit less minimalist as in v.1 though.
When RH10 is attached the program doesn't notice that. I found no way to say to the program that RH10 is attached and have 1G Hi-MD in it. No LUCK. Further efforts to re-open/re-start are not fruitful.
3d try 80min MD inserted
See 1st try.
4th try Blank Hi-MD 1G inserted
Same luck
5th try RH10 attached, no disk is mounted
No luck
Conclusion
Let's wait for version 2.9 which will probably start at least.
Share this post
Whilst this is great stuff I'd suggest any MAC user running Parallels could run Windows XP as a VM (Virtual Machine)--then all the SS facilities are available to you.
Note however that Parallels still does Virtualisation of USB at 1.1 so don't expect lightning fast transfer when you are using an RH1.
Parallels on OS X runs Windows XP fine -- no dual booting etc etc.
Bootcamp is another method but you have to dual boot which is a hassle.
OK I know a lot of people won't bother with "Virtualisation" but sometimes it is extremely useful. You can build for example a Windows VM and only have a single APP (say SS) installed keeping the VM really small. You can have a number of these all optimised for specific purposes and you only have to bring up the VM you need.
Once these VM's are booted you can "SUSPEND" and "RESUME" them at will so no boot / reboot sequences needed.
VM's can be "cloned" so no extra "Activations" needed --Windows essentally thinks its running on the same hardware.
Vmware and Parallels both have "Virtual Network" support as well allowing you to share files seamlessly between Windows VM's (Guest OS'es) or whatever OS you are running in your VM and the Host system (OS X / Tiger / panther).
You can also use (on your Windows VM) the sound output so you can use SS to play files from your library / minidisc without problem.
Both Parallels and Vmware "virtualize" the sound hardware based on the omnipresent Sound Blaster type of cards so pretty compatable with almost every known sound card on the planet. -- Doesn't matter what actual physical sound card you have on your MAC -- the VM thinks it's seeing a Sound Blaster card and works fine.
Just one word of warning -- while you can mix and match any sort of hardware and "Real" machines on your network only Parallels will allow a Virtual Machine to run on OS X. The resulting virtual machine (if it's windows) however will be seen as a "bog standard" windows machine on the rest of the network --this will also allow data from the VM to be shared / accessed across your network.
This makes manipulating and sharing Music Libraries a lot easier.
The only major multi-media problem currently on VM's (running on VMWARE or PARALLELS) is that video streaming isn't yet implemented so if you want to play DVD's then you'll have to do this from the HOST machine and not the VM.
I use this method a lot when I have to run Windows Apps that MAC doesn't have the equivalent of.
Cheers
-K
Edited by 1kyle
Share this post
So if I read this right I can record a show with my RH1 in any setting a choose and upload it to a mac for editing and burning? If I did then I might need to pick up a mac mini.
Share this post
any HiMD setting yes, not legacy modes (these are only uploadable to PC)
Share this post
Just for kicks I tried this with my 1G MZ-NH1. It displays the tracks and folders, reporting the free space correctly. Oddly enough the "delete" function works. When I click the "import" function nothing happens. This is as advertized of course, but frustrating none the less. I'm very close to mothballing the MZ-NH1 and getting an iriver H10 20GB instead. Shame on you Sony for not considering us 1st Gen Hi-MD owners. Sniff.
Share this post
uhm... 2nd gen (the non mac-compatible machines so everything except the MZ-M10 and M100) doesn't have uploading to mac either and they can only download as they can play MP3s without conversion
as said before (and we will probably say lots of times before everyone realizes it):
- only the mac-compatible machines were marketed by sony as mac-compatible (specifically in regards to uploading) -> support for other machines should be seen as an unsuspected bonus if it should ever pop up but the lack of it should definittely not be criticised! you should have known your machine didn't work with mac (it said it didn't in tthe manual and in other places and each shopkeeper should have been able to tell you this!), Sony never promised it, get over it :P
- only the RH1 was marketed as being able to download from mac. now even the 2nd gen machines have been attended to -> again a bonus
- Sony has yet been unsuccesful in porting atrac to mac, so 1st gen as atrac only machines will remain unserved by the mac -> HiMD MP3-transfer software. This isn't evil, this is rather logic...
IMHO if something isn't present when it is advertized as not being present, it is not frustrating! just imagine, I personally would have been frustrated if the 1st gen was mac-compatible all of a sudden, as I have invested another €300 in an RH1 cause I valued mac-compatibility... but I had (and still have) an NH900... if that could do all the RH1 could (without being advertised) I probably wouldn't have invested €300 in a new machine :lol:
PS: if you were lied to by a shopkeeper claiming mac-compatibility at the time, it is another story, but then you should blame/sue/molest :P (I don't really care) the shopkeeper and not blame sony publicly on forums
PPS: my bottom-line (finally :D ) Sony has done quite enough evil/dumb/... things, so if you want to nag and blame sony, just pick one of those real issues, but do not blame them for the one thing they didn't do! Live with it, they added mac support because we all asked for it over and over again, they didn't withheld it from the first gens just to bug you!
Edited by The Low Volta
Share this post
I'm not really cross with Sony of course, but it's a pity that they couldn't have shipped function on OS X that was similar to that on Win32 with Sonicstage. In a declining and/or niche market I think I'd be shipping anything that would keep users using the hardware.
Share this post
This is from the "Hi-MD Music Transfer for Mac Ver. 2.0" manual. One of the notes at the end of page 3:
The following tracks cannot be imported.
-- Tracks that have been downloaded from a Macintosh computer to a Hi-MD Walkman using Hi-MD Music Transfer.
And this from the notes at the end of the first column on page 4:
Audio data downloaded from a Macintosh computer to a Hi-MD Walkman using Hi-MD Music Transfer cannot be re-imported to the same Macintosh computer. For this reason you should make double check (sic) the contents of the original files before deleting them on the computer.
Could someone see if this can be "gotten around" by changing the track name slightly?
Thanks!
Share this post
Thanks!
I doubt that it could because that info is included with the meta data in the mp3.
-Greg
Share this post
Hi Kurisu,
I have not been in touch much with anyone using the NEW Sony MZ-RH1, and uploading old MD live recordings onto a Mac. I have some questions in that regards, perhaps you might be able to answer.
I want to know if there is an English Software for uploading to a Mac, available now on the internet, and where? (Although I live in Japan, I do not read Japanese Kanji)
If I buy my unit from here, can I still download the software in English and use it with the unit I buy from here?
How has the users' response been to this unit? Is it really doing what it is meant to do, and that is to allow musicians to transfer their live recordings onto a PC/Mac, for archiving, or editing purposes?
What has been the overall response to this unit?
Thanks.
Shakuhachi.
Share this post
hi shakuhachi, I'm not kurisu, but he hasn't got an RH1 yet IIRC so I'll answer some of that for you...
- old MDs (legacy MDs or non-HiMDs) will only upload to PC (and only through SonicStage), not to mac (only HiLP, HiSP and PCM recorded with a mac-compatible recorder like the RH1 can be uploaded to mac)
- the English software for mac is available in this very thread you are posting in (or a link to it at least)
- where's 'here'? Japan? then you will have to set the menus to English with the help of one of our Japanese speaking friends, but software wise it's no problem at all
- the overall response to the RH1 has been great IMHO, but only f you realize its strong and weaker points: it is a recorder, not a dedicated player; it does NOT upload old recordings to mac... not at all, excapt for the old realtime analog way
Share this post
Can anyone of you guys post a screenshot of the software.. for those of us who don't have a mac?
Share this post
IPB Image
there you go... nothing fancy, just a small screen that shows the folders and files, you simply drag the MP3s into the screen and they are downloaded to the RH1
Share this post
Has anyone tried accessing the MD through the command line in the terminal and looking at directory with the -a option, show invisible files, ie > ls -a
As I do not have a MD of any description I ould be particularly interested to see if the non Mac supported MDs, which can be used as USB fat volumes, can have their directory structures look at via the command line in the Terminal.app, if so one might be able to copy mp3 via the command line
open the Terminal and type at the prompt (the '>')
cd ../../Volumes
then
cd name-of-the-MD-volumeordrive
then type ls -a
IS there a hidden directory (starting with a ' . ' ) where the audio like MP3s go?
Or is the data volume completely seperate from the audio, like a blood brain barrier?
Share this post
to be playable, music gets 'inscribed' into a special file called 'HIMD' (or something) on the disc... there are no separate MP3 files, nor atrac files. If you combine atrac and MP3 files (as I did with the disc shown in my screenshot: the first album = A3+, the rest MP3) there still is only one file containing the music.
you can drag and drop MP3s, but only in two ways:
- as playable music: D-N-D into the HiMD music transfer window, but this is not real D-N-D, it is just easy interface but the MP3s are nonetheless inscribed in the one 'music file' on the disc and do not appear as MP3s anymore (not even as hidden files)
- as data: simple D-N-D into the disc icon. This is real D-N-D and the MP3s are visible as unaltered separate files, but cannot be played on the machine!
I know little of Terminal and I didn't check this, but I did check this on PC when trying to reimport the MP3s I downloaded from mac, and even with 'hidden files' visible, there are no MP3s, only the music file
at this moment, the disc format itself doesn't allow D-N-D of playable music so unless the playback system of the recorders is completely altered it won't happen... and this means it definitely will never happen for any older MD IMHO... never!
Share this post
Just thought I'd add that the app works with the MZ-RH10, even on my beat up old G3 running OS X 10.3.9
I like the interface - nice and simple.
Shame you've got to install that beast of a program called SonicStage on PCs :(
Share this post
Yep, any recorder that plays back mp3 directly will work with the software. Just can't upload with any non-mac-compatible models.
Share this post
i'm interested in knowing what effect (if any) this has on the "crippled" mp3 playback issue of the generation 2 units. Since this is the closest thing to drag and drop, shouldnt there be a difference in the sound of mp3's as compared to those transferred from sonicstage, or was it deduced that the players were actually doing the crippling, not sonicstage?
Edited by Abbstrack
Share this post
Last night I gave it a try. Here's my gear:
iBook G4 800 w/ MacOS 10.3.9
MZ-NH800
Result:
Softare installs & runs fine. When MD player is plugged in the app can see the tracks. Uploads of any format are impossible. Deletes are possible on unlocked disk. Rename may work. Regroup may work (didn't try).
I wonder why PCM uploads aren't allowed on gen1 players?
Eric
Share this post
This software only works with models that are mp3/mac compatible.
Any model that can playback Mp3 directly can be used with the software to download Mp3>Hi-MD.
Only Mac-Compatible models (M10, M100, RH1, M200) will allow uploads from Hi-MD>Mac .
Share this post
