vbajet32.dll error
Kuoi
Hello ,
After installing Sonicstage 4 , I've got the following error ...
"Application has failed to start because "VBAJET32.dll" was not found. Reïnstalling the application may fix this problem"
So , I did reïnstall Sonicstage 4 again ( 2 times ) , but the same error stayed.
After some searching , I've find out that the "VBAJET32.dll" file was not present in my "C:\WINDOWS\SYSTEM32" folder , so I've decided to copy the "VBAJET32.dll" file from the "C:\WINDOWS\SYSTEM32\DLLCACHE" folder to the "C:\WINDOWS\SYSTEM32" folder , and guess what ... Sonicstage works fine now !
I just post this in case somebody has the same error , and hope for them this simple trick fix their error like it did mine .
Greetings , Kuoi
