HEARDATBEAT
Question regarding Sony's MZ-EH50
23 posts in this topic
can anyone tell me what kind of battery this player uses i'm currently in the market of buying a new hi-md and this one caught my eye :lol:
and also what is the AA cell case
Edited by HEARDATBEAT
Share this post
i think it uses gumstick batteries. the AA cell case is a removable battery pack that u use to attach it to the player if u want to use a regular AA battery, along with the gumstick battery. to get more battery power...u just screw it in on the bottom of the player, but it adds more weight and height to the unit.
but i dont know if it'll work with it alone or without the gumstick battery.
and i hope u have a recorder cuz this one is only a player, and u wont be able to put songs to it with this unit.
http://www.audiocubes.com/product/Sony_MZ-...isc_Player.html
Edited by sector001
Share this post
does anybody have a pic of what this might look like?
For your reference, please review bland10000's MZ-EH50-S Pictorial. Alternatively, you can import the EH50 via PriceJapan.com ~ great customer service and heaps cheaper compared to Audiocubes. richyhu can provide you with more information regarding this importer.
Share this post
yeah well bland10000's pictoral did'nt really explain alot about the battery and what does sector001 mean that i can't put songs on this player please explain?
Share this post
The MZ-EH50 is a strictly "player" unit ~ will only offer playback features. Hence, the need of a recorder such as the MZ-RH1 to record/transfer songs if you will onto a Hi-MD or standard MD discs. For your reference, please review our "MiniDisc Equipment Designation Information."
Share this post
The external cell case
IPB Image
with cell inside
IPB Image
attached to player
IPB Image
Edited by bland10000
Share this post
but then how do you add music to the player?
by inserting a nice shiny (Hi)MD-disc full of music... how do you get music on the disc you ask... well, with another non-player-only unit i.e. a downloader (D-models) or a recorder (RH and NH models)
Share this post
You can employ SonicStage to facilitate music transfer/recordings or conduct real-time recording with a given Hi-MD/NetMD recorder. So, the MZ-EH50 is dependent upon a recorder or downloader for a fun filled music MD disc.
Edit: opps.. refer to Volta's quicker response. :)
Share this post
i don't like the player with this battery case sticking out so imma get the MZ-NH700.
or is the MZ-NHf800 better?
Share this post
MZ-NH700 and MZ-NHF800 are exactly the same except that the NHF800 has a radio in the remote. If you don't care about a radio--I don't--then get the MZ-NH700.
Share this post
get the MZ-NH700.
x 2.
And, a side note. If you want to get radio function on your MD unit later on, you can always buy the 37LT or 39LT radio remote (that comes with the NHF800) separately from eBay, new and usually under US$30. The radio remote will work with both the NH700 and NHF800. Edit: Although I'm not for sure if some areas outside of Canada/USA will get reception. Good luck.
Edited by jaylen
Share this post
x 2.
i had good recepttion with my former 800 unit.........
Share this post
Yeah, but your location is the USA.
Share this post
My wife's NHF800 has good reception in Australia.
The tuner remote is fairly bulky though.
Share this post
and you use an 800 unit..are you all sure that the radio functionality solely depends on the remote?
i doubt it.
Share this post
i doubt it.
I won't speak for the others, but I'm sure enough that I'd be willing to bet your life on it. :lol:
Plug in any non-tuner remote into the NHF800 and you will get no radio reception.
Plug in only headphones into the NHF800 and you get the same thing.
Plug in a tuner remote into specific radio-capable models like the NHF800 (they have a different remote jack compared to non-radio-capable models) and you will get radio reception. From my understanding, the radio is powered by the MD unit via the remote jack, but radio function lies in the remote, not the MD unit.
Hope this clears your doubt.
Share this post
I have an NH700 and an NHF800. I plugged the remote from the NHF800 into the NH700. I got radio reception.
No, this will not work for the NH900 or the RH units, which cannot accommodate the plug from the 37LT or 39LT remote. But the only discernible difference between the NH700 and the NHF800, besides the different model number on the unit, is that the NHF800 came with the radio remote.
Share this post
ok thanks.. didn't know that :)
edit:
will a mz-g-750 (pre-hi-md obviously) radio remote work on a nh700? I can't remember if it uses the same plug.
Edited by flexster
Share this post
edit:
No
Share this post
Create an account
Register a new account
Sign in
Sign In Now
