gym unzips difrent from tutorial
borbit
I've tried to install gym, i used the tutorial from this forum (http://www.gaugestudios.com/nwa1000/)
in the tutorial it says that when you unzip GYM there should be a folder called GYM. in my case all the GYM files are in the root directory. is this a problem and should i put the files in a GYM folder or is it okay to leave them in the root folder?
hi
i put all the gym files in the root directory and it works fine.
Unfortunately it is not possible to use GYM to transfer music to the device. i thought i could:(
is it possible to use the mp3file manager (mp3fm) with the NW-A3000? when i open it, it only recognizes my memory stick port. i would prefer using that over sonic stage.
Edited by borbit
