Converting Problem
Jonesmann
Hey All!
First i wanted to thank you for this great Programm!
But i got a problem..
When i convert a .oma file to .mp3 the file is always very small ~200-500 KB and there is no sound but a noise.
And when i export to .wav this files can't be played..(tried on winamp)
I use the newest Version 0.54 ...
Don't know what to do.. =/
Thanks ..
Hey All!
Thanks ..
What are you really trying to do. What minidisc are you using, what files do you wan to play or record? Give us a little more information, we'll ee what we can do
Bob
You are not using the newest version.. The newest version is 1.00 beta 4
And the problem you're having is probably due to the bug in previous versions not handling mp3 tracks within oma file properlly.. In 0.54 and prior versions these types of tracks produced small files containing static. Just like you described. This was fixed in 1.00 beta 1 ... I recommend you try the LATEST 1.00 beta 4
  • Like 1
