Avrin
A solution to the "slow SP upload" problem on the RH1
Recently, several members of the Russian http://www.player.ru/talk/ forum (including myself) discovered that their RH1s take ages to upload SP. A full SP disc took 50-100 minutes to upload. Yesterday, a member named fsw discovered that this occurs after plugging in an older NetMD unit to the computer you are using for RH1 uploads, and found out that removing all NetMD drivers and plugging the RH1 in again solves the problem. I'll expand on this a bit more.
The problem seems to be caused by some conflict between the driver for the "fast" RH1 (NETMD052.sys), and drivers for older "slow" models (NETMDUSB.sys, NETMD031.sys, and NETMD033.sys), which are designed for NetMD downloading only. If you plug in an older unit, it installs its driver, which then doesn't allow the RH1 to upload at full speed.
The complete solution is the first five steps of the solution to the "Walkman device detection issue", which I posted before. I'll repeat the five steps here, with an update to Step 1, which is absolutely essential:
  1. Disconnect any ATRAC devices from your PC and close SonicStage. Restart your computer.
  2. Go to Control Panel->System->Advanced->Environment Variables.
  3. Under the "User variables for [your username]" field, press the New... button, and create the variable (exactly as shown, without quotation marks): "devmgr_show_details", set it equal to 1, press OK, press the New... button again, then create the "devmgr_show_nonpresent_devices" variable, and also set it equal to 1 and press OK. Press OK again to save the variables and exit the window.
  4. Go to Device Manager, and enable the View->Show hidden devices option.
  5. Find and remove all "phantom" (semi-transparent) instances of "Net MD", "Sony USB Device" (in Universal Serial Bus controllers), "SONY Hi-MD WALKMAN USB Device" (in Disk drives), and "Generic volume" (in Storage volumes). Do not remove any Generic volumes which are not semi-transparent - these are your hard drives!!!
Then plug in your RH1 with an SP disc inside, it will install its driver, and upload at full speed again. And avoid plugging in older units to the same computer again. Edited by Avrin
Share this post
67 answers to this question
The complete solution is the first five steps of the solution to the "Walkman device detection issue", which I posted before. I'll repeat the five steps here:
Totally amazing! Well done indeed.
I have (as I hinted in some other post) for years gone through and attempted to clean up the Windows device map when things got horrible, by hand, using REGEDIT. Whatamess! This finally gives a way to do it properly. as well as solving the bizarre problem of the uploader (RH1) that wouldn't upload per specifications (on speed, that is).
A tip for the less-experienced at all this sort of stuff:
Make sure you reboot AFTER deleting whatever devices you decide to zap. The registry isn't really flushed properly until you do so. It's the act of shutting down that makes things really permanent,
Well I just did an upload at about x10, very impressive.
Then I went and put in a HiMD disk to the same unit, and uploaded something from it. No problems. Finally I switched back to NetMD mode and uploaded something just to make sure the fix hadn't gone away.
All worked perfectly.
What I should like very much to know, is can someone come up with a cute way to allow the other devices to work without this problem. I have several different portables, and I don't really want to wear out my RH1 just to put music on to them. Can you perhaps give specifics of which drivers cause this stuff to happen?
Thank you very much!!!!
Share this post
Looks like any of the "old" drivers can cause this. All my older devices are first and second generation HiMD units, which are using the NETMD033.SYS driver, which does cause this problem. And fsw actually plugged in the MDS-JE780 deck, which uses an older driver, which also caused this problem.
If you don't want to wear out your RH1, you may use older units to download music. Just remove their drivers when you need to upload SP.
Share this post
Perhaps would it work to do some renaming, if some newer drivers will actually work the old units?
Just a thought.
(added years later): there is NOW a set of driver files in our downloads section which solves the problem for ever, and it is possible to use the 052 driver for ALL units with the updated .INF file. This was totally avoided for 64-bit because the ONLY driver we ever had for 64 bits had to be adapted to work with all the earlier units. Going back and doing the same mods to let the 052 driver install for all units meant that the problem raised by this thread no longer happens to begin with whenever a non-RH1 unit is plugged in.
Note that the modified driver set is not signed by Sony (nothing we can do about that) and so each time the driver installs it will be necessary to override the warnings from Microsoft about unsigned drivers. In recent versions of Windows that warning has become more and more difficult to get around but it is still possible. Once the driver has been installed, you don't need to leave the machine in a state which accepts unsigned drivers - i.e. it is necessary to perform this decrease in security only temporarily. Note that the driver ITSELF is unchanged from Sony's version, hence the requirement to have the lowered security at install time only.
Edited by sfbp
Help to newbies to realise this is now solved.
Share this post
The new driver (NETMD052.SYS) is for the RH1 only, and is not specifically designed for older units, so renaming may cause other compatibility problems.
Share this post
i have a great idea! we need someone to make the whole process automates of removing the slower drivers with the push of a button! then we could just push the button and the driver could be removed and the pc could reboot itself. then you could do your sp upload then not have to worry if you pugged in an old device for downloads only. this could be done anytime it was needed
Share this post
So this driver is exactly where to look for the hooks 1kyle and I seem to have some project to investigate. Unless you and your team of experts are able.....?
Share this post
Maybe simply renaming the driver files with a batch file (it hardly needs a program to be written) would work nicely?
Share this post
I sincerely hope so. But then we come to the RH1's firmware. Which was updated 10 (ten) times since the unit was made available to customers.
Installing (not renaming, but actually installing through INF file manipulations) the RH1 driver for, say, an RH910 or an NH600, works, but doesn't give you any new features. But may give you some new and powerful glitches.
Edited by Avrin
Share this post
Just updated the initial post. You do need to restart your computer in Step 1.
Share this post
Just did a little bit of fiddling. I tried to use only two devices, RH1, and NE410, essentially the newest and the oldest (at least as far as my own ownership goes, maybe not historical) devices.
Since you mention the 052 driver is for the RH1, I left it in place. But I renamed all the other three drivers in every place they could be found on my HD (a. windows\system32 b. c:\program files\sony\personal audio driver), namely
NETMDUSB.SYS (to xNETMDUSB.SYS)
NETMD031.SYS (etc
NETMD033.SYS (etc
And now I hooked up the NE410. Windows now asked for NETMDUSB.SYS
So I gave it (just that one driver, by naming it back). Of course that worked (for the download to the 410).
As soon as I switched back to the RH1, now we are back to x1 uploading.
So now I disconnected RH1, did the trick of looking at the hidden nonpresent devices, and deleted (ONLY) BOTH NetMD devices under USB. I didn't delete anything else at all. Obviously I could simply uninstall the one whose driver is shown (by looking under properties) as NETMDUSB.SYS, leaving the NETMD052.SYS installed.
Plugging the RH1 in now got a device installed (because I just deleted both devices), only one NetMD device now, the one whose driver is NETMD052.SYS.
I'm not sure what the 031 and 033 are, possibly something for one of the other devices. No data yet. But it seemed the whole problem arises from the conflict of NETMDUSB.SYS and NETMD052.SYS.
Note added: i looked inside the various .INF files and you can too, sure enough the 033 is required when I put an SP disk into my NH600; it looks like the 031 driver is only required for NE810 and AM-NX9. All the other HiMD units require 033.
Then I confirmed that the 033 driver ALSO causes the 052 driver to go slow; In the driver file list for the RH1 there is now 033 as well as 052, and now it doesn't behave correctly any more. The only way to correct this is to delete the MD device and let Windows rebuild it again.
Maybe I'll just set up a second computer for NETMD uploads with the RH1.
Share this post
The data are in the respective INF files (with same names) under the [ControlFlags] section, in ExcludeFromSelect lines.
The data are not complete.
And the NE410 does actually require the NETMDUSB.SYS file.
Edited by Avrin
Share this post
I just had a bright idea, what if we could convince the USB devices to hang off two different device chains. Then I would use one connector for the RH1 and another cable entirely for the rest.
YUP, THAT WORKS!
If you check, there are now 2 NetMD devices in the Device Manager List (and two NetMD's listed in SonicStage, wonders will never cease!). One of them is the RH1 and runs at full speed and has only 052 driver. The other has both 052 and 033 (not exactly sure why, someone will probably explain this) and can run the NH600 (with LP2 disk in it) quite fine.
If you're not sure, please don't hesitate to ask questions. I feel like saying "Eureka!". I had all sorts of ideas about lying to the software about drivers, etc etc, but this seems to solve it.
Stephen
Share this post
YUP, THAT WORKS!
Until it stops working. I always plug in all my HiMD devices (in any mode) to the same USB port. One of the four.
To me it looks like the whole problem is not a driver issue, but just a glitch...
Edited by Avrin
Share this post
Turns out it's not a glitch.
Just connected one of my NH600s in NetMD mode. Well, Windows promptly installed its NETMD033.SYS driver. Then I restarted my 'puter. And connected one of my RH1s. The "50 minutes to upload an SP disc" thing was back. Then I followed what is described in my first post here (without restarting). The RH1 works @10x again.
Edited by Avrin
Share this post
But if you plug the RH1 into one port, and the NH600 into another, you should find (as I did) that they are independent of each other, and that the RH1 NetMD device never "picks up" the 033 driver. No need to uninstall anything once you got it set up right. The older units will never cause the 052 driver to be loaded (you can see why from the .inf file).
And ne'er the twain shall meet. Worse case, delete a device when it goes wrong. I plan on labelling the two cables "RH1" and "the rest"
Share this post
Awesome work!
EDIT: Just tried this out, and all I can say is WOW!!! What a difference!!
Absolutely wonderful!
Edited by raintheory
Share this post
Is it possible that RH1's have been wearing out prematurely because of this bug?
Share this post
What a great piece of work, awesome topic Avrin :ok:
* Thread Pinned
Share this post
Quite possible, since it has to work longer to upload the same amount of information. The disc spins/stops more times, etc.
Just tried this (plugging the NH600 into another USB port). No luck. The RH1 SP upload still slows down. I think this may depend on hardware configurations.
Share this post
Yes, I deliberately took one cable to the front of the PC, and one to the back. Judging from the list of devices on this particular machine which has always listed no less than 4 USB controllers, I think I managed to get one cable connected to each of two different controllers.
Hint: USB controllers always seem to come in pairs. So if you take the socket closest (horizontal or vertical) to the one you are using, it's possible it may not work.
Good luck!
Share this post
Still no luck! I've tried all four USB ports on my notebook. Plugging the NH600 into any of them slows down the RH1 upload. Despite the fact that I also have a set of Intel® 82801EB USB controllers.
Share this post
Try going back to the way I did it. Rename all the drivers and only put their right names when the installer pops up asking for file name. Don't try out the upload until the driver list (for each NetMD device) looks clean.
Another thought, have you set the RH1 in SP mode default on record before connecting it? This means that when there is no disc it defaults to NetMD operation. Maybe if it's defaulted to HiMD operation then it goes ahead and dumb-ly loads > 1 driver?
Sorry, I thought this might be simple. I have 4 ports on the back of the machine (on the motherboard) and 2 more on the front. Could it be something about the way Windows manages them?
Share this post
The unit had an SP disc inside before I connected it.
This is quite possible. Another possibility is that the 4 ports on the back of your machine are physically connected to another controller than the 2 on the front.
Edited by Avrin
Share this post
Not 100% sure if this counts the same as having the machine default to SP with no disc. I suppose I am imagining writing a driver - and one has to start from certainty. Otherwise users would see different results starting with different discs... states are multiplied by 2.
I agree. That was actually my intention. But I don't see them on the device list.
Share this post
Maybe a bit of overkill but a possibility is to use a Virtual Machine for uploading RH1 and another VM for uploading music from other MD units.
You can use FREE M$ Virtual PC or VMWARE's VIRTUAL Player. On Linux you can use the Free Virtual Box as your virtualisation software but it's rather unstable.
The best way is to create vmware capable Virtual disks with (FREE) QEMU and then use Vmware's virtual player to run your VM -- this gives you the capability of running and creating Virtual machines compatable with Vmware workstation without the cost of buying vmware workstation.
For Windows follow this link
http://johnbokma.com/mexit/2005/10/26/vmwa...windows-xp.html
For Linux do similar -- download the QEMU Linux package and build the Virtual machine the same way--most Linux distros already have vmware player installed by default --if not just download and install for your linux distro.
You only need to create minimal Windows virtual machines -- you don't have to install all your normal apps. You could probably run these in 256MB RAM easily so even a modest modern dual core laptop could quite comfortably run two of these concurrently.
You might be able to create Windows 2000 virtual machines (avoids problems of Windows XP activations) -- although I'm not sure if the RH1 driver will run on Windows 2000 --in any case the fast usb driver might not work -- Net MD units will be fine on Windows 2000 BTW.
I'm running Net MD transfers on Windows 2000 and the RH1 on Windows XP virtual machines.
Cheers
-K
Edited by 1kyle
Share this post
