Sony Insider Forums
Sign in to follow this
TheCase
More inputs via wireless
Hi,
I can only plug one mic into my MiniDisc at the moment but if I want to plug more how and wirelessly ... I dont really want wires everywhere :)
Thanks
Share this post
Hi,
Thanks
A small mixer so that each of the Wireless receivers have its own channel and level control then run the mix to the Md unit
Share this post
So I'm looking at this
http://www.maplin.co.uk/Module.aspx?Module...er&doy=17m7
Idealy the setup should be mixer at base with wireless reciever ... other wireless reciever on people and the the minidisc will be at base with the mixer. I have corded mics though how can I get them wireless is there some kind of adaptor?
That is a Passive mixer for line level stuff , and it doesnt sound very good ( it is just a fixer ) for a few more duckies , you can get a MUCH nicer mixer .
but yeah that is the idea.
Share this post
The Tapco , is much better built , and yes there are adapters for turning a balanced mic to a wireless .
how many channels do you need ?
Edited by Guitarfxr
Share this post
I need 4
Thanks
Ok look at this mixer , Tapco Mix.60 .( Tapco is Mackie's budget line so you get a Good mixer on a budget price) Notice channels 3,4 , on the inputs there are two ways to go in , ( Mono =Left input only , or Stereo on 1 channel both inputs )
also notice that there is EQ on Each channel ( VERY IMPORTANT ) a little EQ can solve a HUGE amount of problems in the Bass area ( To much or to little etc .) getting a Balanced sound between all the mics , each persons dynamics are a little different , so each channel gets a little different setting for a better overall sound scape .
Share this post
Thank you very much. How can I wireless my wired mics?
That is the expensive part , Wireless transmitters aren't cheap
The best place that will have access to the most info , is FullCompass , I have dealt with them a lot over many years , good people , good company .
http://www.fullcompass.com/
Share this post
Create an account
Register a new account
Sign in
Sign In Now
