Windows 7 64-bit Sonicstage 4.3
#1
Posted 22 October 2009 - 02:41 PM
Now that Windows 7 is offically released, have any of you beta users had any success installing Sonicstage 4.3 onto your 64-bit systems? Everything I look at says it's not compatible. However, I did see one person had tried a XP compatibility mode. Does that work under 64-bit?
Thanks in advance.
Nathan
#2
Posted 22 October 2009 - 02:59 PM
No I haven't tried it, as I don't have a need for Win64 currently.
#3
Posted 26 October 2009 - 04:50 PM
SonicStage 4.3 + Windows 7 x64 (RTM) = No Problems at all! <=== no XP compatibility mode needed
Used with: MZ-NH1, MZ-RH1, NW-S703F, NW-A808, NWA3000
Upload download ripping transcoding titling.... general use is working as you would expect!
#4
Posted 26 October 2009 - 05:46 PM
Stephen
#5
Posted 27 October 2009 - 10:03 AM
#6
Posted 27 October 2009 - 10:27 AM
I'm interested in the response because brother-in-law asked me the same question and we ended up poring over spec sheets for different intel processors, and looking on microsoft.com for answers to such questions. An affirmative from OP here would shortcut a lot of mucking around
#7
Posted 27 October 2009 - 12:23 PM
Edited by Avrin, 27 October 2009 - 12:23 PM.
#8
Posted 27 October 2009 - 02:32 PM
However this sort of reminds me of running DOS drivers under Windows 95. It worked!
#9
Posted 27 October 2009 - 03:00 PM
And I don't think that the RTM version of Windows 7 already includes Windows XP Mode. After all, it's a 500 Mb download.
#10
Posted 02 November 2009 - 11:11 AM
#11
Posted 02 December 2009 - 02:56 PM
#12
Posted 19 May 2010 - 05:01 PM
#13
Posted 19 May 2010 - 06:04 PM
You'll only get WinXP compatibility mode in the non-base versions of W64.
(note: this information is now out of date, there is a NetMD 64-bit driver available in our downloads section).
#14
Posted 19 May 2010 - 10:42 PM
yes - as long as you only need HiMD, it should be fine. NetMD will not work unless you have WinXP 32 bit compatibility mode. HiMD is using only the file system over USB, essentially. NetMD has its own protocols and drivers (being from an earlier, and coincidentally, more paranoid) era.
I only record in PCM or HI-SP with my RH1. I strictly use it as a recorder and nothing else...so I should be good to go.
So any version of Windows 7 should work just fine for me.
#15
Posted 28 April 2011 - 10:33 AM
It shouldn't make a difference...byt I work with technology far too much to trust it and my music DB is 78GB...would hate to lose it, and I'm installing Win7 since my XP died....
#16
Posted 28 April 2011 - 10:37 AM
#17
Posted 28 April 2011 - 10:46 AM
I assume you already decrypted everything? IF NOT, STOP RIGHT THERE AND REVIVE XP FOR LONG ENOUGH TO DO SO....has anyone here tried restoring a music DB made in XP with SS 4,3 running on 64-bit Win7?
If you did decrypt it (File Conversion Tool) then the files can be used in anything where you can actually install SonicStage.
NetMD drivers are a whole separate issue, of course. All is well unless you need M-Crew and PCLink.
I have never done the Sony-provided backup/restore. I bow to Azureal's expertise in this area.
Stephen
#18
Posted 28 April 2011 - 11:34 AM
Stephen
hmmm...not sure what you mean by "decrypting"...I just use the backup tool and let SS do its thing....?
All of the files are in .oma format and not .mp3, if that's what you mean.
#19
Posted 28 April 2011 - 12:51 PM
If not, and anything at all goes wrong you are up a creek without a paddle (actually a friend of mine has figured out a way round it, but this information is not public yet, and possibly may never be).
You need to get that XP box up, at least temporarily, or you are in for all sorts of unpleasant surprises, IMHO.
#20
Posted 29 April 2011 - 08:24 AM
I mean that you ran the File Conversion Tool and DEseleted the "copy protection" box.
Thanks for the info. I never, ever, ever use copy protection though - the vast majority of my music is burned straight from CD. I'm hoping that means I don't have to worry about this problem!
