Line in quality
Soundbox
In two weeks I will be making an important recording where two microphones will be used (and fed into a mixer). I was going to take my NH600 and use the line in as I have done in the past for similar projects (but with a MZ-R30), but now after reading here on the forum I am wondering if taking my JB980 deck will yeild a better recording? Both the NH600 and JB980 offer ATRAC-R but what about the actual record quality. The portable is my first choice (no mains lead - my mixer runs from a PP7 battery), but if the deck is better then I will make arrangements ahead of time. The concert is two classical guitars.
Thanks for any thoughts, Ian
PS. I forgot to add - I will be using best recording quality - SP - so no need for long play.
It is likely that the deck has a higher quality A/D converter than the NH600, but with increases in large scale integration and chip design, it is also possible that the NH600 which is 2 years newer than the JB980 may be on par with the deck but I doubt it. I know I have an older JE20ES and it has very high quality A/D chips for that all important conversion from the real world domain into the digital one and it makes fabulous recordings in SP format, but it is still highly compressed at 292 kbit/s as compared to 1,411.2 kbit/s.
As Arvin says, using 1GB HiMD discs will allow you to get 90 minutes or so of high bit rate PCM recording versus 80 minutes of lower rate SP recording on the deck, that may be the biggest determining factor. I think the PCM on the RH600 will be a cleaner sounding recording than the SP on the JB980.
My two cents worth ...
Thank you for the thoughts - very interesting to me as someone who does a fair bit of recording.
Just to clarify my use of SP mode - I am often asked for a CD copy of the concert and to make this I use the optical link from my JE510 deck (will be the JB980 this time) to link to my Denon CD recorder. I use the CD Sync mode to place all trackmarks from my MD to the CD and then I can burn more CD's on my laptop from this master CD. If I used PCM then I would have to use the headphone output from my portable and whilst that is probably better than my 'optical SP' method I don't want to take a risk as I would hate it if it was worse after the concert.
Thank you again, Ian
Either - Or, Neither - All!
- It crossed my mind that you may have discounted the option that BOTH means can be used - if you have two sets of microphone.
Why? Because then you WILL be able to answer your question authoritatively - not based on predictions of technology. Many times in the past I have used superior 'technology' only to find that older-tech. performed the better!
Also, you will have a 'backup-up plan' in place in case one method fails - you said that the recording was 'important'. [i always plan two independent methods when something is that important; or, to plan a risk profile on the one method with contingency plans ready.]
Whatever you do, unless you're going into production, surely either method will yield great results! :dance2:
Hope it goes well.
Regards,
mdmad.
BTW do we get to hear a sample when you've finished? Just a small sample ... it'll give an extra dimension to this thread, methinks!
Sure I can share a sample - what is the normal way of doing that? I can post audio only to YouTube - is that good enough quality?
Ian
Personally, I share by encoding to lossless, say FLAC, and then going to http://www.rapidshare.com/. FLAC should be available to download for free, for Windows, on the net. I use Linux, and it comes 'out of the box', yahoo!
It's all pretty obvious from there: I suggest no more than 5mins sample though, otherwise upload takes too long. (~20MB). You can do more if willing to wait ...
YouTube, in my experience, always transcodes and will not be fair to your recording. Nevertheless, you can try it, but set the highest bitrate.
If you don't get anywhere with the above, PM me for help.
Regards,
mdmad.
  • 3 months later...
Which Denon CD recoder do you have? I didnt know you could do this.
I predict the results will be so close that PCM might actually less pleasing than SP. I find SP to be a very pleasing codec and with a wild guess speculate that PCM might pick up sounds that even in a studio might not be desireable. I can't wait to see what the results are, I am by no means an expert.
I *think* but it's only a guess, that the magic of MD is the filters applied when recording. I think the only problem with PCM is when it's not properly mastered.
Certainly having owned a good PCM recorder (RH1), I would always use it for live recording so I can afford to amp up the sound without loss of quality. Doing so with compressed sound is liable to produce artifacts, right?
Where the input level is known in advance, I would record at whatever compression I can get away with.
My CD recorder is the CDRM30 http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/589 - a very useful gadget. I have been having a bit of trouble with my musicians. First one was ill, then they could not set a firm date. I am ready anyway so as soon as they give me the call I will be over. I have done soms quite nice SP recordings with just a solo guitar but not enough experience yet with PCM to hear a real difference.
