Sony Reader éRS-600 Charging Problem
  • Please log in to reply
3 replies to this topic
#1 Ela Inoelloc
Ela Inoelloc
    Newbie
  • Members
  • 2 posts
Posted 21 August 2010 - 02:39 AM
Good Morning.
I have a problem about my PRS-600. I'd like to charge it without buying the original charger so I decided to charge it via usb. It works, but just from a PC. If I connect, e.g., to a Blackberry charger or another USB charger it shows me the screen "USB connected" but not the battery symbol, and It really doesn't charge.
Is there a charger that works? And a generic charger that I can buy on the net?
Thanks
Alessandro
#2 sfbp
sfbp
    Inquisitor
  • Administrators
  • 3,631 posts
Posted 21 August 2010 - 07:29 AM
I believe the USB charging design is similar to that for minidisc units. You can buy an inexpensive multi-voltage charger (the kind with a choice of heads) from a drugstore. This will charge into the special (not custom, just purpose-built) round socket to the left of the USB. Just set it to 4.5 or 5 volts and you should be fine. No need to buy an expensive one from Sony.
The USB charger for the MZ-RH1/MZ-M200 does ***not*** work with this unit.
#3 Ela Inoelloc
Ela Inoelloc
    Newbie
  • Members
  • 2 posts
Posted 21 August 2010 - 07:37 AM
Thank you.I have tryed with more than one of generic chargers, but in noone I found the right cable for this socket.
Could you advice me one on the net?
Alessandro
#4 sfbp
sfbp
    Inquisitor
  • Administrators
  • 3,631 posts
Posted 21 August 2010 - 11:06 AM
Here.
You don't state where you live.
