Corey A Downs
My MDS-JE500 went belly up.
7 posts in this topic
I've had a MDS-JE500 for about 6 months now, and now it won't record. Every time I try to record I get a "Retry" and then a "Retry Error."
According to www.minidisc.org, the MDS-JE500 had a problem where that happened if you tried to start titling/labeling within 10 seconds of starting to record. My problem usually happens within 2-3 seconds of starting to record and them goes in an endless loop of "Retry" then "Retry Error" splitting into another track every time.
Now.....
A) Can I fix this?
B) Sony told me it would need to be repaired. How much could this cost?
C) (I think this is in the wrong section) Does anyone have a JE520 or any deck in the 6** or 7** section that they sell for under $100?
-Corey
Share this post
I Have a similar problem with mine but on mine it is intermittent so i can still record but some discs it dowsn't like i've tried many discs new sealed ones and it still does it so i don't know how to fix it but i would love to get mine working like new even though i baught it off ebay about 6 months ago and it didn't record when i got it but I have this intermitterent problem now,
sorry for the ramble,
any help would be appreicated.
Lrp55
Share this post
Did you clean the recording lenses (gently) ?
If one of our technician aficionados here like NGY or sfbp (Stephen)  can help you, perfect. But considering the actual value of such a deck, maybe it would simple to buy a new one.
Share this post
I was thinking of buying those lens and head cleaner discs one disc for lens and another for the record off amazon cuz that's where they are cheapest or can u recommend a method that won't damage them?
Cheers
Lrp55
Share this post
Seriously, guys don't even consider using 70% Isopropanol. You should use only pure (99% or 100% on the label). I dread to think what is in the 30% in the bottle above.
And it is almost never the head cleaning problem. There are a gazillion things which can cause failure to read. Most common is (gradual) loss of laser power.
Share this post
Commonly ultrafiltered or demineralized (cheaper) water.
Nowadays meaning buying a new deck instead trying to find a "new" lens + setup.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
