Service Mode MZ-NH1
  • Please log in to reply
6 replies to this topic
#1 stargazer_tom1
stargazer_tom1
    Member
  • Members
  • Pip
  • 49 posts
Posted 25 March 2012 - 08:55 PM
Hi,
Does anyone know the button sequence to enter service mode on the MZ-NH1.
I would like to apply the volume hack to a non European region if possible. I cant find a definitive answer on whether or not the NH1 has the volume cap applied for European models.
Thanks
#2 bluecrab
bluecrab
    Professional
  • Valued Contributors
  • 606 posts
Posted 26 March 2012 - 03:33 PM
Did you check the SM?
http://www.minidisc....e/MZ-NH1_sm.pdf
Might be in there.
#3 stargazer_tom1
stargazer_tom1
    Member
  • Members
  • Pip
  • 49 posts
Posted 26 March 2012 - 08:48 PM
Hi,
thanks,
The service manual does not outline a key combination (like the MZ-RH1). Apparently I need to use xp with simple burner and some other sony program to get into test mode. Has anyone managed to get into test mode with the NH1?
#4 sfbp
sfbp
    Inquisitor
  • Administrators
  • 4,096 posts
Posted 26 March 2012 - 09:05 PM
Try this - you'll need the RM-MC40ELK connected of course.....
turn on Hold
hold down group
FF FF RW RW FF RW FF RW || || (the last two are pause). (the user manual calls RW "FR", a strange designation).
(for all I know you may be able to do the FF and RW on the 40ELK but I wouldn't bother). However once you have it in Service Mode, you may want to use the Vol+ and Vol- buttons on the remote instead of the ones on the 5-way control.
To get out of service mode remove the battery.
Now, if someone could only tell me how to get into service mode for the EH70 (not that it matters since neither of mine has the Eurocap).
I recently bought one of the HD generation (NWZ-A1200 to be exact). All the Eurocap seems to do is to make the whole thing utterly muddy. Once I had removed it, I could listen happily at 10 or 11 where before had me turning it up to 19-20 and still cursing the loss of clarity which is the ATRAC trademark. Sort of like building a Ferrari and then insisting it run on cotton wool wheels...? I sympathise with your predicament.
#5 stargazer_tom1
stargazer_tom1
    Member
  • Members
  • Pip
  • 49 posts
Posted 26 March 2012 - 11:32 PM
Thanks Steve will give it a try. I remember getting a NWZ-A1000 when it came out. If i turned the EQ on the volume level would decrease! It really frustrated me!
#6 stargazer_tom1
stargazer_tom1
    Member
  • Members
  • Pip
  • 49 posts
Posted 26 March 2012 - 11:41 PM
It worked thanks Steve!
For anyone else who wants to follow what I did I changed item 113 to 01 as shown on this post:
http://forums.sonyin...-your-own-risk/
#7 sfbp
sfbp
    Inquisitor
  • Administrators
  • 4,096 posts
Posted 27 March 2012 - 08:32 AM
Well done! I edited my post to delete the reference to menu, since presumably the group button was the one required. If that's not the case (ie menu is the constant button held down) shout loudly. I don't want to be responsible for people trashing their gear.
