#1
Posted 21 April 2012 - 08:21 PM
thanks
JD
#2
Posted 15 June 2012 - 01:16 AM
#3
Posted 15 June 2012 - 05:06 AM
As long as you stick to SP (no choice with an R70), you should equal or beat the quality on a standard CD. The more likely problems are:
1. What microphone you use (many will cut out at 30, 40, 50 Hz), and whether the fancy mics will work in the microphone socket of the MZ-R70. You may need a device called a battery box to transform the signal from the fancy microphones to line in voltage levels, instead of the microphone input, due to the signal levels involved.
2. How you plan to get the results digitally if you need to do scientific analysis. Just about the only reasonable way to get the recorded sounds from an SP minidisc is to buy or rent an MZ-RH1 and upload the SP minidisc to a WAV (16 bits, Fs=44100) file. Anything else you are likely (but not guaranteed) to lose the upper and lower ends just by transferring it (you can test this if your equipment is good enough, on a scope or whatever) on an analogue cable.
All in all, you're the scientist, and will have to establish your own means and methodology.
The one thing you do NOT have to worry about is the compression - ATRAC does a very good job on that score. What it lacks in overall bits it makes up in bit depth. ATRAC is a 24-bit format with a logarithmic exponent (floating point) whereas Linear PCM is a 16-bit fixed point format. So for very loud and very quiet sounds, ATRAC will probably work better than one of the devices that merely records 16-bit "LPCM".
Hope this helps.
#4
Posted 21 June 2012 - 04:02 PM
thanks again for your input.
JD
#5
Posted 22 June 2012 - 02:37 AM
Its frequency response is very deficient in bass and superhigh treble. T he bass is more serious. There are two octaves of human hearing below 100 Hz.
http://reviews.cnet....7-20037945.html
The R70 will grab good sound, but you ned a good source.
#6
Posted 20 December 2012 - 11:29 AM
I am having some problems when I switch the recording mode from SP stereo to mono on the MZ-R70. There are times when the recorder seems to identify silence while in reality the source is emiting sound. When I'm digitizing the recording, whose length could be 10 minutes, those sound blanks make it shorter, some times loosing up to 2 minutes of sound because it pauses constantly. This doesn't happen when I record mono on my other MD, MZ-N707.
#7
Posted 20 December 2012 - 12:56 PM
#8
Posted 20 December 2012 - 01:07 PM
Do you think dirt inside the socket could cause this? I no longer have the unit so I can't check but I would just like to identify the source of the problem to avoid it in the future.
#9
Posted 20 December 2012 - 04:06 PM
#10
Posted 20 December 2012 - 04:10 PM
ok, how are dry joints fixed?
#11
Posted 20 December 2012 - 05:19 PM
#12
Posted 21 December 2012 - 01:43 AM
Yes, it could be a bad contact or cracked solder joint around the microphone input. Dirty contacts is fairly common, bad joints not so but if the input has had a lot of use? That said, I would have expected a more chaotic signal than clean on/off as the graph. Unfortunately there is no indication of time duration on the x-axis. Also seems odd that the problem is reported in Mono, not SP Stereo.
A staccato signal would be the result of the laser not being able to read the track reliably. A constant signal would be played back with intermittent blank sections, which could range from milliseconds to several seconds each time. But then, the playback time would be extended to include the blanks, rather than reduced. We can presumably rule this out.
Could it be the output of the R70 that is intermittent? Have you tried both earphone outputs? I am assuming you are taking the recording from one or other of these sockets, into the line input of your PC card. Have you tried the same recorded disc in the N707, does that produce the same inconsistency? In which case it is definitely the recording at fault, not the playback. Can you be sure the microphone does not have a bad connection in the cabling? Are the discs you are using good quality and in good condition, ie not dusty and scratched?
Final question: Are you absolutely positive the [problem never happens in SP, only Mono? If the latter is true, I would reckon the problem is in or around the encoder, which means a main board swap.
Sorry for the ream of questions, it's just easier for diagnosis if all the possibilities are dealt with in one go.
Jim
#13
Posted 21 December 2012 - 09:26 AM
Also I know that cables for PLAYBACK with non-gold contacts (eg many headphones) can be really awful. So maybe the dirt theory isn't so far wrong in the first place, if one thinks non-gold==dirt
Edit: I just thought of something. This could easily be a Windows problem. If you look at your volume control in Windows (for recording inputs) you may find there is (or can be - see advanced properties on the mixer) an input called "Mono In". It might be be that you need to select this to prevent the input from going crazy when it gets no signal from one channel.
#14
Posted 21 December 2012 - 09:56 AM
Hello Jim, I've uploaded a new screen capture with the time line on the x axis. Unfortunately I didn't try the second headphone socket and since that unit was stolen from me I can't check. I'm sure the microphone is working properly as I constantly use it with the N707 (the connection is in deed gold). The disc was in good shape, HOWEVER It did combine both stereo and mono recordings, something I stopped doing after this incident. I never had this problem using the R70 on SP Stereo (using the same mic, disc, battery etc.) so I reckon this would only happen on mono. I can't try to digitize that recording on another unit because the disc was in the recorder at the time I was robbed.
Hi sfbp, I digitize all my recordings using a standard 3.5mm audio cable (non-gold) but this has never been a problem in the past (nor now).
thank you both for you input!
JD
#15
Posted 21 December 2012 - 10:17 AM
I'd still be inclined to suspect the line cable. One way to resolve this would be to see if you can hear with your own ears the "bad" sound from the mono recordings, using the headphones and using the line cable routed to an amplifier. I would always avoid a PC for making direct recordings, personally. Latency is always an issue, as well as pickup electronic noise from the other components plugged into the (PCI) bus. Here's the picture of my Volume Control:
volcontrol.JPG 42.5K
5 downloads
#16
Posted 21 December 2012 - 10:33 AM
In deed sfbp, I can hear the 'blanks' sending the sound from the computer to my stereo's line in and connecting my headphones to the computer as well.
#17
Posted 21 December 2012 - 11:56 AM
But that is AFTER you transferred to the PC.In deed sfbp, I can hear the 'blanks' sending the sound from the computer to my stereo's line in and connecting my headphones to the computer as well.
Can you hear the blanks with headphones plugged in the recorder?
#18
Posted 21 December 2012 - 04:50 PM
You mean I should record the recording using the MZ-N707? I no longer have the original disc in which the recording was made, so the only way to listen to it is via a computer. I guess I could re-record using the 707 but I'm guessing the blanks will be recorded as well.
#19
Posted 21 December 2012 - 04:58 PM
Also tagged with one or more of these keywords: amphibia vocalization, md
Categories →
Minidisc →
Technical, Tips, and Tricks →
MZ-N10Started by Octaedre, 06 May 2013 |
Miscellaneous →
Classifieds →
[WTS] MD blanksStarted by mrgaijin00, 24 Feb 2013 |
Miscellaneous →
Classifieds →
Wanted NEW MZ-N10 Battery, called SONY today...Started by quantumtom1, 23 May 2012 |
Categories →
Minidisc →
Am I too late ?Started by From Distance, 27 Oct 2011 |
Categories →
Minidisc →
Transfer music from MD to PC through digital outStarted by lioriris, 23 Sep 2011 |
