Sony Insider Forums
MDietrich
Tweaking any MiniDisc recorder - FOR FREE (with spectacular sonic results)!
Hi guys & gals!
I´ve written an article - about MD again - where I describe a tweak to improve sound quality of any MiniDisc unit. This tweak basically describes how to use an equalizer to improve the ATRAC encoding. I really think that the results are spectacular and that they should be shared with anyone else. Enjoy the article!
http://marlene-d.blogspot.de/2013/09/spectacular-sounding-minidisc-tweaking.html
Share this post
Actually what you describe is done automatically by many situations when either:
a. Sony decks or portables record; or
b. Sound Forge converts; or
c. SonicStage transfers (with conversion).
However it is possible as many people have discovered, to beat the "automatically" by choosing some slight screwy conversion or sequence to pass the sound through. This is why, IMHO, ATRAC failed the critical test comparisons back when it was actually competing against MP3. The organizers of the test tried to find a "fair" way to compare. Unfortunately there probably isn't one, and in doing so they triggered the effects you describe in your article. Thus the ear is the only way to be sure you are making a decent, "keeper" recording.
Yes, I can record good classical music off the radio at 66kbps (LP4) onto a deck. It comes out well. But the weirdest of things will mess it up. For example double mono announcer (attributable to the fact that LP4, unlike LP2, is joint stereo ie signal + difference). For example too much good data such as a 320kbps signal.
If you want to get good LP4 rips from a CD, for example, it may be advisable to rip to a format of intermediate bit rate (256 or 132 kbps) and then convert a second time from the intermediate form. This ensures that the proper equalization is one (after all Sony "knows" that you don't really want to convert CD to LP4, heheh). Forget all the nonsense about doubling the mythical "ATRAC generation losses" - it's all about achieving the transformation you describe.
And I swear I can tell stuff that's been RECORDED at MP3 immediately. Converted to MP3 isn't such a problem, as Sony and others learned to do similar tricks to what you are describing sometime after the fact.
Stephen
Share this post
Yes, many lossy codecs do this. Yet they all try to keep those high frequencies. They base their 'decisions' on how loud this content is. ATRAC however shouldn´t have been enabled to encode them in the first place... it never was the best codec. With ATRAC3 Sony was wiser since they remove this content anyway, especially LP4. But not ATRAC1 4.0 and higher.
Look at the samples I uploaded:
this is the standard ATRAC encoding. You can see that ATRAC tries to keep frequencies beyond 15.5 kHz. It does this based on their gain. Generally, the ATRAC codec isn´t good enough to keep those frequencies.
My 15.5 kHz cutoff gets rid of them and enables the rest of the spectrum to be encoded in a superior way.
Share this post
In other words, Sony ***knew*** this about the original (SP) Atrac, and took steps to quietly ditch it in favour of a more reliable, modified scheme (in A3 and A3+). The problem they were left with was (is) compatibility.
So SP has a special flavour but it's not necessarily the most accurate; it's what people got used to hearing. Makes perfect sense (to me) since for most, what came before SP was analogue. HiSP with a better encoding scheme and almost as many bits is probably better (well, more accurate).
Share this post
This sums it up perfectly.
A few weeks ago I´ve read a comment on Tapeheads were somebody was talking about sonic differences between the MDS-JA 50 and the MDS-JA 555. The first with ATRAC 4.5, the latter with DSP Type-R of course. The JA 50 was described as sounding 'warmer', the more recent as too cool. Without knowing it, this person wasn´t talking about actual differences between the two units, he merely described ATRAC codec differences.
With my method they both will sound the same. Say, the sound quality of DSP Type-R turned into a non-existing, theoretical DSP Type-Z. Not everyone will like it though, since using my method creates a sound even closer to the pristine CD original, it simply sounds less 'warm'.
Share this post
Hello, I enjoyed reading your article. I downloaded the two wav files and listened to each wav file with the 3 samples on each one.
I was surprised they pretty much sounded the same.
Could you just clarify when you listen to them you are noticing a big improvement?
Share this post
Yes, I indeed do. Occasionally, these differences are bigger as differences from, say, two different portable CD players.
Share this post
Count me as one who likes the "warm" analog sound, as from the MDS-JA20ES. My older ears don't care much why I like it better than the admittedly more-detailed MDS-JA333ES, they just do. I've read the somewhat famous JA555ES/JA50ES review/comparison several times now, and I would like to get hold of the JA50ES. Much easier said than done, though. IMO, an MD unit's DAC may be almost as important as its ATRAC version. DACs really do vary in sonic characteristics.
Share this post
I know what you mean... the JA50ES is a legend. I wanted to own it the moment it came out. But for used units the price is so high... I´m afraid owning it will forever be a dream. I myself would go for the JA555ES (or JA333ES). Although the reviewer makes a very convincing point by mentioning that the JA50ES with its warmer sound might make recent Loudness-War recordings bearable. On the other hand, I usually get rid of Loudness-War-related artifacts myself.
In case someone else wants to read what we were talking about: http://www.tapeheads.net/showthread.php?t=16445
Share this post
Fascinating articles although not sure my ears would notice significant difference. Having said that of the two MD decks I've owned, both Sony, D-D40 & JE480 I've always preferred the sound of the D-D40. Not sure why it sounds any different, and I only ever use SP so it's not down to the ATRAC type S of the 480. Was the output more tuned to the CD player combined in the D-D40?
I'd really love to hear what you do with "loudness war" recordings, they annoy the hell out of me. It'd be great to be able to take one of these obnoxious sounding CD's and copy a much more "mellow" version to MD.
Share this post
MXD-D40: DSP Type-R, JE480: DSP Type-S. However, if I remember correctly, the MXD-D40 received very good reviews all those years ago. I´ve never heard it myself of course and I´ve also never read a review about the JE480. So maybe the MXD-D40 simply is the better sounding unit. The recordings themselves (from both recorders) should in theory sound the same.
Getting rid of the Loudness War? Try 'ReLife': http://www.terrywest.nl/utils.html
It´s a VST-plugin (you´d need a host for it). As a source, do you employ a digital output on your PC like me? If so, you´re in luck: just increase bit depth to 32 bit floating point, then 'treat' it with ReLife (volume is diminished by -4.21 dB to make room for 'new', interpolated dynamic peaks) and leave it in 32 Bit floating point. Play that back with 24 bits using a player like foobar and record to your MD units. You have to be aware though that ReLife introduces a slight (or severe, depends on how you look at it) low frequency phase error (which doesn´t hamper encoding quality but might introduce sonic errors).
In general, I treat 90% of everything I have on my HDD with ReLife and I love the result. Although the actual sonic difference is smaller than expected.
Wrote an article about this: http://marlene-d.blogspot.de/2012/09/need-to-panic-disease-loudness-war-is.html
Share this post
There's a subtle difference, at least from what I can tell. I'm not any kind of audiophile or someone who understands the specifics of encoding music, I have trouble distinguishing the difference between 192kbps MP3 and 320kbps, but then I don't listen for the differences, I just listen to the music haha. As long as it sounds good to me I'm happy.
Share this post
Try DFX audio enhancer... http://www.fxsound.com/dfx/ , not too much with lossless files.
Share this post
I wouldn´t use that for one minute. It´s a cheap thing aimed to people who don´t have any idea whatsoever about audio. It´s for people wanting bass, volume and pseudo-surround. The advertising looks like 'Dude hits some knobs and gets more bass.' This plugin makes everything worse and it sounds awful, it really does (listen to it more than 10 minutes and you´ll know what I mean: it is never subtle and it makes lots of errors).
It´s the opposite of getting rid of the Loudness War. And this tool lies blatantly... like all those 'all-in-a-box'-tools. It promises that 'remastering' is as simple as a click of the button - which it isn´t.
Share this post
imho the sb x-fi crystalizer enhances the sound a bit.Ok you need the x-fi card for that but i don´t think this is any worse to the sound.
Marlene can you say something about it ? i used to use this on a x-fi xtreme gamer proi version that i don´t use atm.
sadly the card in my htpc is an audigy 4 in whose drivers respective hardware that can´t be enabled.
I thought the only good way way to get better sound through hardware, isn´t it ?
Share this post
Using the X-Fi crystallizer AND the DFX audio enhancer at he same time is a good source of distorsion, I agree with that, Specially with lossless files. But il is also a question of original recording level (that is why I always use now the Replaygain plugin). On my desktop (before it recently failed) I used only the X-Fi crystallizer plus optical out / foobar2000 / Ks or Wasapi audio outputs / Replaygain.
DFX audio enhancer - fixed once for all at 5.0.0.2.2 - is still usefull (and most of the time with no distortion...) with my laptop on board audio card (no X-Fi...). I promise to forget it completely when I will get one day for example an M2tech interface and a DAC Naim audio :imsohappy:.
But as I have started to use (slowly) the "DAW" Samplitude pro, I hope to make some progress one day in my recording quality using some of his features :heat: , banishing forever DFX !
Share this post
If one keeps the amount of influence of the Crystalizer small enough it might work for some material.
One could do that himself... add bass, treble and presence area, a bit of peak limiting, resample all of it to 96 kHz with a so-so resampler and make it 3 dB louder.
I had a X-Fi once. Never used the Crystalizer... this should be telling enough. My X-Fi HD USB uses the next version (without resampling I think) and I´ve never used that either.
But all of this is the opposite of getting rid of the loudness war.
Yes, you have much more control with a 'DAW'. The thing with DFX audio enhancer is that it isn´t subtle, it cannot be configured to work with precise markings. So the only thing it produces is hyper compressed, distorted music.
And the Crystalizer and DFX? Gosh, your poor ears.
Share this post
Hi guys & gals!
I'm just curious, when doing CD -> MD optical recordings, which will produce better MD recordings: portable MD Type-R recorder or MD home deck Type-R recorder? I've heard the using MD decks can produce better recordings because of the available power for computing/encoding/compressing. If a bit is a bit (0 or 1), wouldn't the sound quality be the same no mattery which Type-R recorder you use? Thanks.
  • Like 1
Share this post
Oh if only life was that simple. This whole subject of "aren't 0's & 1's all the same" has been brought up in countless forums in the past. If this was true all MD's would sound the same, all cd players would sound the same, all DVD's, etc, etc. And we all know they don't.
Even if we have two MD's that are both type R they may well have different DAC's plus there are a multitude of other things that can influence the sound before it reaches your ears. Whether or not these differences are always noticeable is sometimes debateable.
Someone more knowledgeable than myself can probably expand on this topic far better than I can.
Share this post
That is indeed a very good question. I´ve asked this several times now (not necessarily here at this forum) but no one has yet answered me. I´d prefer some measurements but people generally don´t seem to care.
I´d love to know too. There are many guys with a DSP Type-R home deck around, I could send one of them a testfile which would need to be played back in 24 Bit by the optical output of a PC and recorded by the optical input of the Type-R-equipped MD home recorder. The disc with the testfile then needs to be played back by the MD home recorder and recorded digitally by the PC - again in 24/44.1. The result would need to be sent to me for analyzing.
BTW, I do NOT refer to the quality of DACs, MDs or anything else. This is just about possible encoding differences between portable and stationary recorders.
Reason: several Sony manuals seem to suggest that stationary MD recorders have a superior encoding quality.
Share this post
HI..
Just send me the file and i´ll be glad to record it with a JB930QS. The Soundcard iam currently uisng in my HTPC is an Audigy4.. so 24 bit is no problem at all.
I already recorded a file to test the DAC´s between the JB930 and the JB980. Same way as you described..It was a 24/48 file from Yello.Oh yeah :D
Is that a good choice to test with ?
I send you a PM with Email if youo like ;)
Share this post
How about just using a regular CD deck with optical output and connected to the portable Type-R recorder and then to the MD deck Type-R recorder. I do all my optical recordings from a CD recorder deck.
Share this post
You cannot encode a 24 bit signal using that method. CD only accepts 16 bit. And any possible improvement of stationary decks will be eaten up by the quantization noise caused by those 16 bits.
Share this post
HI..
Can I say it? I love you! ;)
Just kidding. But I AM extremely thankful that you have offered this. And on the JB930QS of all things - gorgeous.
BTW, a 24/48 file is not the best thing to use for your MD recorders. Feeding them 24/44.1 is the better idea. Reason: they need to resample these 48 kHz files to 44.1 before it can be recorded to the disc (the MD cannot work with anything else). While the resamplers used for the MD recorders were very good all those years ago they aren´t so good in 2013. Most software resampler people can use for the PC offer a quality way higher (right now thinking about the free SoX plugin for foobar2000).
Share this post
Create an account
Register a new account
Sign in
Sign In Now
