Sony Insider Forums
Happy Hopping
Where do you buy good quality gumstick battery for your CD or MD Player?
I have the Sony E-DJ2000, it's 1 of the thinnest CD player, a collector item
The battery is Nh-14WM, this same battery is use on a lot of MD player as well.
I bought some compatible from ebay. They are horrible, junk made in China
they don't hold charges. They hold for a few days or even a few hr., then the battery strength totally disappear
then there are these dealer that sells compatible, like do you take a chance w/ them, or what can you do?
http://www.gnbatteries.us/servlet/the-350/prismatic-gumstick-battery-Sony/Detail
how do you guys fix this problem?
Share this post
The real question is: how do you charge them? Do you have another battery that works decently in the E-DJ2000? Are you charging that by the same method you used to charge the replacement batteries?
If the answer to both the last questions is yes, but the same charger doesn't work on the replacements, try cleaning the contacts.
When that doesn't work, I recommend an MZ-R91 (or MZ-R90) as for some reason the charging circuits in that device seem to work better. You may find that the battery gets hot (only once!) on charging and then settles down.
You're welcome to slip one (I assume you bought lots) in the mail to me, as I see you live not so far away. Send me a PM if you like. I will pronounce on it, and send back. This will be quicker than ordering more from China.
Share this post
I charge all those batteries via the charger inside my E-DJ2000 charger. I just assume it's the age of the battery that it fails.
How exactly do you clean the contact? w/ sand paper or alcohol wipe?
Share this post
I'd be more inclined to get a custom charger. Or an MZ-R90/91. You can try cleaning with isopropanol, and/or a very sharp knife (scrape a bit) or boxcutter.
Share this post
I'm also wondering where to get decent quality gumsticks. I see loads of the Vapex ones on eBay and they certainly look far more "legit" than the HQRP ones on Amazon (though I used some blue offbrand ones that looked very much like the HQRP ones back in the early 2000s, and they worked fine), but they're all shipping from the UK so that's annoying.
Share this post
how many years is your HQRP lasts and how much did you pay?
See back 10+ years ago, I did buy the real sony gumstick battery made in japan. The truth is, they don't last long neither. I remember I have problems w/ it after say just over 1+ yr.
So going w/ what you guys said, what is a good quality charger? I prefer 1 that can charge 2 batteries at the same time
Share this post
I bought a Vapex one from ebay, and one also came with my N710, I can tell you that they hold a decent enough charge, but longevity wise, couldn't say.
Share this post
I picked up a couple of NiMH gumsticks on eBay with the label "PowerStream", I don't see any for sale currently by the same seller but they seem to work great, hold a charge and run for nearly a week of 2 - 3 hours of use per day.
This seller was in the US but I am sure the batteries are made in China. Both I bought have been charging and discharging for 6 months or so without issue.
  • Like 1
Share this post
I´ve often read that those types don´t hold the charge... well, let me tell you something: they´re not able to. No NiMH battery is (with the exception of Eneloop). Furthermore, those NiMH need to be discharged (but not completely) before being charged again.
While they don´t have the 'Memory Effect' of NiCD batteries they have something else. Imagine you have a NiMH battery that´s still charged at 40%. If you charge it to a 100% it´s at a 100% minus the 40% it already had before charging. So effectively you´re now at 60% masking themselves as 100%. This happens every time.
For that reason I´ve bought this: http://www.technoline.eu/details.php?id=1400&kat=15
It´s the best charger on the market IMO (it´s available in other countries than european too under a different name). It discharges NiMH batteries before re-charging them, it also has a refresh function which works marvellous. But it isn´t able to charge Gumstick batteries. To do that I use two copper cables, elastic rubber band to firmly attach the contacts of those two cables to the poles of the battery and something to press the other end of those cables to the connectors of the charger. That way, my NiMH gumstick batteries have held up for more than two years - and they are the same cheap ones you bought.
  • Like 1
Share this post
When we said it wouldn't hold charge, we are saying that w/i a few days, if you don't use it, the charges drop drastically. OF course, w/i a 3 to 4 wk. time frame, we don't expect 100% of the charge to hold
Share this post
Yes, it´s quite normal for any NiMH (again: except Eneloop) battery to loose the charge that fast. On the first day alone it´s usually 5-20 % and after that stabilizes around 0.5-4 % per day.
Warm temperatures? Faster discharge (at 45° Celsius 3 times faster).
Cold temperatures? Slower discharge.
Furthermore, the higher the capacity, the faster the discharge (exception: Eneloop).
Share this post
I bought one HQRP gumstick to see how it goes.
Kinda surprised really. The NH-10WM inside my "new to me" E520 is the original battery shipped with the unit... which means it's like almost 8-9 years old at this point, yet I spent probably 7+ hours listening to music on the player since I charged it up. Battery hasn't friggin' budged.
Share this post
Where did you actually buy the charger from and how much for? Thanks.
Share this post
Got my generic gumstick battery in the mail. It's supposed to be 1450mAh; I'm charging it up right now. Like the old blue ones I used to get, the plastic is a little loose around the negative terminal and I had to trim it up a bit so it'd go into my E520 easily.
We'll see how the capacity is soon enough. :3 The NH-10WM that came with the E520 is only 900mAh and is the same age as the player (several years old) and still gets about 25-ish hours of SP playback. If the generic green battery can get ~35 hours I'll be pretty pleased.
Share this post
Hi MD,
Thanks for pointing that out
of the battery charger.
I have bought one.
It is really a beautiful object.
Have a nice day
S.
Share this post
nice little gadget. i use the charge terminal pro. an old device i bought in the 90´s but gets very well results. It is much larger than the one you´re talking about.
the alive function of mine is quite good.. i didn´t test any other chargers so can´t compare that well.
Share this post
Well I've been using my generic green gumstick battery for about five days now and it seems to be doing quite well. I've been listening to my E520 for about 2-ish hours a day on average and the battery hasn't been charged since the day I got it, and it's still at 3 bars (though it sometimes drops to 2 bars and then goes back up to 3).
Share this post
I second the praise of the "Powerstream" batteries. Label shows "API Batteries" search of the API battery site does not show these gumstick batteries. Maybe the seller on Ebay had a special run of these gumstick batteries made? I bought two of these and was so impressed I ordered five more. These hold a charge like the original Sony gumstick. Watch Ebay if you find them get them.
Share this post
I am seriously NOT at all impressed with a replacement gumstick battery I bought on ebay!
I purchased a High Power 1450mAh Vapex rechargeable battery which does not even hold a charge! I've charged it a few times now in the Sony MZ-N1 portable, start playing a disc, lasts about 4 songs then dies of low battery warning.
Even If I just charge the battery up, then return to it the next day without using the player, it's already dying.
If that's the so called quality of gumstick batteries nowadays, it doesn't look bright for the players that use them.
Share this post
I am considering divesting in all players/recorders which cannot be run from an AA battery directly or via a sidecar battery compartment.
That excludes the RH1 which is really like a mini-deck and I never run it from battery anyway.
Share this post
The generic green 1450mAh gumstick battery I got from Amazon holds a fantastic charge. I managed to get two and a half weeks of near-daily use, around 1.5-3 hours SP playback per day. The original Sony 900mAh gumstick it came with is quite old and thus holds only about a third of that (it still works, though).
Share this post
I have the MZ-M200 model and looking on eBay has the battery LIP-4WM 3.7v, 370mAh Li-ion battery for $58 not adding the shipping and handling. I should purchased a spare at the time I purchased the unit. The battery is in good condition; but, looking around comes up negative. Thinking eBay might be the only location and the battery is coming from Japan.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
