Sony Insider Forums
Sign in to follow this
chris348
Sonic Stage Ultimate Release 2 Installation Problem on Vista
Erased the Sonic Stage Software in error a while ago and when I tried to download from Sony, found that they had withdrawn it. Tried to load Sonic Stage Ultimate Release 2 from this forum, but the software did not install Sonic Stage. (The step was shown, but was apparently skipped). Help please, as my minidisc (NET MD Walkman MZ-N505) works fine.
The computer is Vista 32 bit, SP 2, fully updated.
Have performed extensive Google searches for Sonic Stage software, but all you seem to get are lots of dodgy downloads. I have the original software CD (v2.2), but it will not run on Vista.
Many thanks in anticipation.
Share this post
61 answers to this question
I don't see why that affects Sonic Stage. Generally system dll changes would not have any effect on a roughly 10 year old app like Sonic Stage.
It may be good advice... but OTOH you may just end up placing restrictions on the software you're installing. My vote would be NO although I'm sure there are situations where SFC is quite useful.
YMMV.
Share this post
It works!
You haven't told us enough to figure out what's going on. At the least give us a screen shot of the last step which you think worked during installation, and a screenshot of the first error message you see (during installation). About how many minutes into the install did things go belly up?
Are you 100% certain it isn't in fact successfully installed? Check the main Windows menu to see if there's anything there or not.
You most definitely don't want anything to do with SonicStage 2.2
It maybe that you haven't removed the old software properly.
Share this post
It works!
Many thanks for the prompt reply. Have done the following since yesterday.
1) Used Revo Uninstaller to completely remove all Sony software, including left-over files and registry entries.
2) Downloaded SS43-Ultimate from the forum, moved it to the desk top and ran it from there.
3) An installation window appeared with 7 stages, from 'Music Server Controller' through to 'Driver' Will try and add the screen shot shortly.
4) Each stage took a few minutes to install, except for the 'Sonic Stage' stage, which passed almost instantly.
I now have something called 'OpenMG Secure Module' 26 Mbytes-ish (do not know where this is), and very little in the Sony folder in Program Files, one OpenMG Jukebox folder and one Personal Audio Driver folder.
Presume that there should be a Sonic Stage program somewhere. Do wonder if there is a left over registry entry that makes the installation program think that Sonic Stage is already installed. There are no error messages.
Thanks again for any advice.
Share this post
The main Sonic Stage program is called (for historical/marketing reasons) omgjbox.exe
Hope this helps.
Share this post
Hope this helps.
Have tried again erasing all previous Sony software, including left-over files and registry entries, and re-installing, with no apparent success.
What I do not understand is that there is something called OpenMG Secure Module 5.0.00 shown in both Programs and Features and the Revo  install list, the registry entry for which says it is in Program Files/Sony Corporation/OpenMG Secure Module.
However, there is no sign of such folders when Windows Explorer lists the contents of the Program files. There is no sign of omgjbox.exe anywhere in Program Folders.
Thanks again for your time.
Share this post
You should search for omgjbox.exe on your entire computer's hard drive. When/if you find it, this should give you a signficant insight into what's wrong.
Did I mention you should probably run the install (and indeed all the executables from Sony) as Administrator? Either your user needs to have admin power, or you need to make shortcuts which run the program by default in administrator privilege mode. It is ESSENTIAL to disable all antivirus and other scanners whilst running the install, as well.
Share this post
Am afraid that trying all of the above at the same time has not changed the behaviour of the installation program. The 'Sonic Stage' stage of the installation is still completed in an instant as though it is being skipped. There is no sign of omgjbox.exe anywhere on this computer. Are we at the end of the road?
Share this post
I doubt it. But it does seem quite likely something is wrong with your computer. What were the last few things you installed? Any disk utitlities, or anti-spyware/malware/antivirus?
What did you pick for destination? Try c:sonicstage
There's one other possibility, if you really were running an old version of SonicStage before (you mentioned 2.2?), maybe it's still there and you didn't actually get rid of it at all.
And you should turn off DEP and UAC - I don't recall what the default settings were for that ill-fated version of Windows.
Time to try installing something other than SonicStage. First try something non-Sony, such as Nero (any old, and I mean old, version should do, not the very latest). Then try Simple Burner (maybe that's all you need anyway).
Share this post
Have disabled DEP and UAC and the Virus checker and run SS43_Ultimate as Administrator. Still no SonicStage files were installed. The directory should have been c:/Program Files/Sony/SonicStage. There is an OpenMG Jukebox folder containing two files, neither are .exe. The 'Sonic Stage' stage of the installation again is conducted in an instant.
Regarding loading software, have just loaded an update for OpenOffice. This loaded perfectly.
Share this post
This sounds most peculiar.
Have you tried running the INSTALL program in XP Compatibility Mode? (I assume there's such a thing in Vista)
This sort of nonsense may be why people didn't like Vista.
Share this post
Many thanks for yet another suggestion. Assigned the compatibility property to the install executable as XP Service Pack 2 (you can do this in Vista). With the anti-virus disabled and run as administrator, the installation program behaved precisely as before.
Share this post
All I can think of was that Microsoft was in the early stages of their attempts to enforce partition of users' data and programs along per-user lines.
I think it's essential for you to try creating a writeable directory on the root (If you cannot, there's part of the answer) of C: and install to there. I have the deepest suspicion of installing programs to C:Program Files
Another thing to check is access to C:Program FilesCommon FilesSony Shared
Start by deleting everything in there, which is where a lot of the guts is stored. Don't bother about de-installing. Just keep on installing over the top until things work. You can probably figure out how to get rid of the excess afterwards.
You did say there was plenty of storage on C:? If you are booting from an SSD or (worse still) ROM, all sorts of bad things may happen. Hint: Sony used self-modifying code in this product.
And I don't think installing an update to Open Office is enough of a test. You need something with a bit more of a footprint. Like I said, try Nero.
Share this post
Have tried various other things this morning. Firstly, the C drive is 290Gb, of which ~100Gb is free, I can create a file on the c drive eg. c:sonic, put files in it and take them out again. Not sure where the PC boots from. There is no SSD.
When I alter the destination folder in the installation process, the software appears to ignore any change and such files as are generated are placed in c:program filessonysonicstage, as well as c:program filescommon filessony shared.
Have a busy week or so looming, so will not be able to pursue this further.
Thanks for your help. It is a great pity that Sony could not leave the software on the 'net somewhere, even if they were not able to provide any support. Can't think it would have cost them much to do that.
Thanks again.
Share this post
OK. Now we're getting warm.
The reason it ignores the destination is that it finds a previous SS installed. The executable omgjbox.exe should be in that "sonicstage" directory, wherever you put it.
Somehow you have to really really clean your computer of this (old) stuff, i.e. previous SS releases. I'm wondering if somehow you tried installing 2.2 from your CD over top of a (downloaded) later version. This could well account for what's wrong. It's helpful to everybody to hear about such weird stuff as we end up dealing with it.
Or try to install on another machine.
Share this post
Will try to clean the machine as best i can. Am happy to have a real good look through 'program files' etc., but could the problem lie in a left-over registry entry? Can run a registry cleaner, but do not want to delve in the registry other than that, given the harm that I may do.
Share this post
Undoubtedly that program location is stored somewhere in the registry.
One more thought before you begin - is there a custom uninstall program that was placed on your HD by Sony during installation of SS 2.2???? Run it.
Thank you Sony, I found the string to D:sonicstageomgjbox.exe in at least 10 different places in my registry.
So.... first you gotta uninstall everything that looks related in the list of installed programs. In my case that's only SonicStage. But maybe you have Simple Burner installed, that might enough to lock you into C:Program FilesSonysonicstage
Then you need to get rid of the Sony shared stuff you referred to.
Then you need to go through and religiously remove every reference in the registry to
C:Program FilesSonysonicstageOmgjbox.exe
Whilst you are doing this, probably you will want to delete most of the hives containing these references. Be careful not to delete anything which contains the above string AS WELL AS OTHER UNRELATED stuff.
Oh yes, and as you go through, delete whatever these entries point to! There's a lot of stuff.
Examples of things you can delete you'll find lots more):
HKCROmgjbox.exe
HKCRsonicstage
HKCRsonicstages
HKCUSoftwareMicrosoftIntelliPointAppSpecificOmgjbox.exe
HKLMSOFTWAREClassessonicstage
Almost any key name with omg starting it (look for clues that it's Sony-related).
Don't forget to REBOOT before you install anything. It's the rebooting which freezes the registry. And empty the trash.
And above all, don't panic. I have no idea why this should be necessary, but this is what I would do if I had the problem myself.
NOW - search for Sony ******ANYTHING AT ALL containing the word Sony******* (of course if your computer is a Sony product this approach won't work). And get rid of it. In most cases you will want to delete the entire hive that contains it.
Good luck!
Share this post
Thanks again for the excellent advice. Have tried the clean-up suggestions on both the C drive and the registry that you made yesterday and may have another try shortly. However, still the exactly same installation problem exists.
I have just found the attached installation log file. Will have a look at this myself shortly to see if I can make any sense out of it.
One thing I did not do was to run the OpenMG un-install file as this would have meant re-installing and then un-installing OpenMG 2.2.
Thanks again for the help.
omginstlog.txt
Share this post
There is another set-up log file, but the reply software says that I cannot upload files of this type, even though it is only a 12k text file. You are welcome to have a copy if you can suggest a way of transmitting it.
Share this post
Also.... went into the unpacked set of files generated by the install software and found the folder pertaining to sonic stage ... C:UsersChrisAppDataLocalTempSS43_ULTIMATESonicStagessEnglish... Double clicked on set-up and nothing happened (tried several compatibility settings), which is what is happening in the install process. All the other modules appear to be working OK, and may be run by clicking on their setup.exe, except for the SonicStage module.
Share this post
Stop right there..... who said OpenMG 2.2????
We should be up to 4.3 or even 5.0 if I remember correctly.
What's its name?
Share this post
OpenMG 2.2 is the CD that was supplied with the Minidisc as original equipment. I had tried to load it onto Vista a long while ago and thought that you were suggesting that I should run the uninstall program that came with it. But I may have misunderstood and anyway have not.
The other log file is 'C:UsersChrisAppDataLocalTempsoniclaucinstall.log'.
Here is the other log file. Now I've changed its name to install.txt the reply accepts it.
install.txt
Share this post
You definitely need to get rid of OMG2.2
But I think you will find if you check control panel, it should say OpenMG Secure Module 5.0.00
I'm becoming convinced this is simply a case of deleting something that is already on your computer. Less is more, if you will.
I looked at the file. Could it be as simple as you haven't disconnected the MZ-N505?
Share this post
Reading through some of the posts, there appears to have been some success in loading ss43_ultimate onto 64bit windows 7 machines. Also have a laptop running that OS, so have just tried to install it. Exactly the same behaviour as for the vista computer. The sonicstage part of the install is over in a flash and there is no sign of sonicstage in the installed list of programs, although the OpenMGsecure module 5.0.00 and the drivers module appear to install.
Share this post
You must be doing something consistently that others don't do. Are you connected to the internet, I wonder? It may be there's some authentication step you don't realise.
Thousands of people have downloaded the 64-bit drivers and are using SS with Windows 7 (having installed the exact same package as you). Did you unplug your MD (the error in your second logfile)?
Another question: have you tried double-clicking on SetupSS.exe? Or sonicstagessEnglishsetup.exe? (for this you will need to have unpacked things a bit). Did you notice that SetupSS.ini mentions UNinstalling omg2.2?
Share this post
Have tried double clicking on sonicstagessenglishsetup.exe in the unpacked files. Nothing happens, which is what happens in the overall install procedure. If i double click on the setup file that produces the secure module (in "C:UsersChrisAppDataLocalTempSS43_ULTIMATEcommonopenmgsetup.exe"), this works fine and installs the secure module. But why is the sonicstage setup looking for an external server? Is this the one that was withdrawn by Sony some 18 months ago.
I think that the original sony software required access to an external server..
Both computers have been connected to the net all the time, which is a bit scary as i disabled the virus checker.
omg 2.2 is long gone.
I agree it is all rather strange. Do not usually have such problems.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
