paul stratford
Webcam not working on Sony Vaio
I have a Sony Vaio SVE1512J6EW running Windows 8.1. The webcam has stopped working it's disappeared from device manager. Can't find the software or driver I need to get it working again.
Share this post
1 answer to this question
Found this on web: hope it helps
The drivers used by the camera on sve1512j6 are the standard built-in Windows system drivers so you can probably discount that as a cause if the device is not present in Device Manager.
To eliminate a system glitch try the following:
Open Device Manager and expand Universal Serial Bus Controllers and then delete all in that tree by right clicking each device and selecting ‘Delete’. Shut down, remove the battery and AC power adaptor, and hold down the power button for 30 seconds. Reattach the AC adaptor and battery and reboot. Windows will reinstall all Serial Bus Controllers and hopefully the camera will now be recognised.
If this fails to have any effect you will need to consider the possibility of a hardware fault. This will be an expensive repair, if out of warranty, but a cheap alternative would be an external USB camera.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
