fourbanks
Sony MDS-JB 940 Static Mini Disc Player (fault)
61 posts in this topic
Hi friends
I have just noticed on my new Sony MDS-JB 940 Static Mini Disc Player that on inserting the disk it says reading TOC and plays well . however on ejecting the disc it says eject then goes straight to the message reading TOC without ejecting
The unit has only been used once before storage many years ago. hopefully i will be able to fix it as our good friend Jim is no longer here ?
Edited by fourbanks
Share this post
I have received the belt from Holland i never realized how small it was ? it is straight forward to fit ?
Share this post
Dead easy. Just make sure you don't leave the belt twisted if it ends up that way after you first put it on.
If I recall correctly, this is roughly the sequence
1. Remove lid.
(EDIT) If there is any disk in the unit, persuade it very gently to come out, using whatever tools you have to do the work of the belt that's not working (i.e. push the eject button and "help" it to eject). Probably easiest with the power on. (EDIT)
2. disconnect ribbon cables making sure you know where they go back (it should be obvious) leading to the mainboard from the MD unit. ONLY DISCONNECT ONE END OF EACH.
3. Undo the grounding straps (they are push fit), I think there are only 2 you care about, making sure you know where they came from.
4. Remove/loosen the front panel (6 screws or so), only enough to remove the MD unit. See the service manual. If you're smart you won't completely undo it.
5. Undo the 4 "flying saucer" screws anchoring the MD unit into its rubber bushings.
6. Now you can take the MD unit into your hand with no wires or anything. Prise the plastic mechanism by squeezing just enough to let it open past the (plastic) stop and open the main hinge very very carefully making sure not to bend or stretch anything particularly the overwrite head. You should be able to replace the belt now.
Putting it back together is easy. The service manual shows it all (the DISassembly of course). Nota bene: you should not have to disassemble the MD unit itself. Particularly if you get to something that says "remove solder" stop immediately and reconsider your fate.
Good luck
Stephen
Share this post
Snap a couple of pictures of the unit internals before you disassemble to use for reassembly.
1 person likes this
Share this post
i still have this work to do but will get round to it. if i need to eject the disc i just have to put some pressure in the opening and it ejects but as i say i'll get round to it
Share this post
Be careful you don't wait. It will eventually jam and you will be sorry... very sorry.
Share this post
well well well. I thought I would check my store of mindisck decks jb940 and one also  now shows the same problem! Does time  deteriorate the belt esp when not in use or maybe the storeage conditions?  This is the first time this has happened to me. is it common? as it was fine when stored away and never gave any trouble of any kind. By the way where is the service manual referred to above as it seems I will have to do the same job!!
Share this post
well I started to dismantle mine. it is nt necessary to undo the front at all as once the  saucer screws are undone it lifts out clean. re the grounding straps - cant see any. Now just got to get to the belt,  the instructions above a bit un clear. I can see the little  belt from the front? only one belt? What should I expect to see? a broken belt? Mine is still intact and in place.Just slipping then? and a new one will do the job?
Edited by freddyjollo
Share this post
hopefully freddy that is all it will be ?
Share this post
fourbanks have u sorted yours out yet? did the belt solve the problem?
no freddy like you i'm looking at it but i'm sure it will be not to difficult
Share this post
to open the "main hinge" I think you have to remove a small spring at the side that otherwise keeps it closed. This is a very small spring with not too much tension that I think could easily be damaged so do with care. I havent got to that state yet, as I am waiting for a spare belt to arrive.
Share this post
i will follow your lead we can do this together when your new belt arrives
Share this post
The spring is no big deal, but you may want to remove it early just to make sure it doesn't get bent out of shape (it's easy enough to bend back). The belt, on the other hand can slip quite easily and no amount of adjusting springs etc. will make any difference to the mechanism functioning properly.
Share this post
on a related matter do any of the cheaper Sony decks use the same transport? might be worth picking up one cheap just for the mechanism?
Share this post
A lot of the decks around that time use the same mechanism. However there are different cable widths (17,19,21,23 pins on the principal cable from MD to mainboard). So one must check AT LEAST that the 2 cables have the same number of pins. It has to do with the extra control lines related to M-Crew/NetMD support (remote), IIRC.
Share this post
i'm afraid this did not go well as the piece of the laser broke off so if possible will need to put the rest of this unit into a old 920 uk model like the lighting unit ? and the belt i have just brought  ?
i have a tv electronic engineer who works close by so he may be able to swap some of the parts over ?
Edited by fourbanks
Share this post
Can you take a picture?
i have dropped the units over at the at the engineers so i'll leave it up to him as the best way forward. the laser unit of the old 920 did work but has been heavily used. He might just swap that over but failing that he will if able just swap the main light unit over as it's new and will just keep all parts for a later date
these things happen and if i came across the same model will get another this was just bad luck
will keep you posted
Share this post
You cannot put the 920 disk unit into the the 940. Sorry.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
