sweetbabala
iTunes to MD?
4 posts in this topic
Hello.
If it's possible, can someone please explain how to transfer files from my iTunes "library" to MD? I have done some searching but can't seem to come up with much. I would be using SS 4.3 and either an MZ-NH1 or RH910.
Thanks very much,
Ryan
Share this post
Have you try to convert your iTunes audio files in the audio formats that are accepted by SonicStage ? The trick of just rename the files from .m4a ( MPEG-4 ) to . mp3 (MPEG-3) is not working very well. I would advise you to use dBpoweramp Music Converter, even if that mean to convert files by number of 10 only each times with the free edition. Oher sofwares : Total Video Converter, Easy CD-DA Extractor, etc.
More details about SonicStage 4.x here https://en.wikipedia.org/wiki/SonicStage#Version_4
Share this post
Thank you very much, PhilippeC, for your suggestions. You have been very helpful and I was able to move all the songs over to MD. More dust on my iPod, I suppose.
Ryan
Share this post
Is there something i didn't uderstand here ? SS4.3 imports iTunes AAC files to MDs, the only problem is that it doesn't recognize well the tags in AAC apple files. (so it's put under a "blankname" folder)
Share this post
Create an account
Register a new account
Sign in
Sign In Now
