Zeugitai
Partially Solved: MZS-R5ST gone dark
10 posts in this topic
(Update: The portable unit was not seated properly in the deck. Incessant poking and pushing resulted in the seating of the rear corner of the MZ-R5ST into the MZS-R5ST deck and, voila, the power came on! I ended up just cleaning the old system batteries and putting them back in for the time being.)
[Original Issue:] I took my old faithful MZS-R5ST out of storage, plugged it in, ejected and reconnected the MZ-R5ST player unit, and the whole deck went dark. My heart sank and it hasn't come back. The unit was not misused or abused. On the contrary! However, it was stored for some time. It did light up when opened, and it did eject the player. Then...darkness. Pressing the power button, opening and closing the display lid, nothing.
[Remaining Issue:] The two internal rechargeable batteries are corroded.  They are Ni-Cd, 'AA', and according to the schematic in the service manual, page 61, 3v.  Does anyone know where to find these, or acceptable equivalents? I 'chatted' with Sony service today and was told these batteries are 3.7v. each. Nicd's are hard to find anymore. Will rechargeable batteries of 3.7v. and, perhaps, Li-Ion chemistry work as well?
Thanks!
Share this post
Your old NiCd AA cells (1.2V nominal) are probably dead, after having spent such a long time in storage. This unit can take regular - AA size - alkaline batteries (1.5V nominal). If you have other gadgets that run on NiMh AA batteries (1.2V nominal), you can also try two of them.
Share this post
Thanks.  To be clear, I am talking about the two _rechargeable_ Ni-Cd batteries that are nestled in the system board and require disassembly to reach.  As I recall, I bought this in Taiwan in 1997, or so.  It is a thing of beauty, and I always took care of it, and even stored it carefully. Nineteen years, however, take their toll regardless.
 I found the service manual on the Internet this morning, and on page 61, among the schematics, a note reads:
RECHAGEABLE
BATTERY (Nicd)
SIZE "AA" (IEC DESIGNATION R6)
2PCS 3V
Trouble is, batteries like these two are obsolete and even Sony does not have them in stock. My originals are corroded and need replacements.
Share this post
The internal batteries for the timer are "nc-aa660ft"
seen these batteries ? I think most if not any 1,2V AA cell will do the Job
http://www.ebay.de/itm/Batterie-Telephone-sans-fil-pour-SONY-MZ-R5ST-/351516807256?hash=item51d808d058:g:pEYAAOSwPgxVSFGM
I´ll check my unit later.probably my batteries are drained out too.
But as i never used the timer function it didn´t happened to cause any problems.
1 person likes this
Share this post
HUH?
Sony is right, 3.7V, this beast takes a LIP8. I have several, and an MZ-R5ST. No NiCads for me.
Share this post
RECHAGEABLE
BATTERY (Nicd)
2PCS 3V
The internal NiCd batteries can be replaced with NiMH ones. The charging scheme is very similar of the two, the device would work with the replacements properly. Once you are about to replace them, make sure you buy the new NiMH AA cells with connecting leads welded onto them (example), as these batteries don't like soldering. Or you can simply use a two cell battery holder, if there is enough room.
As for the voltages: IEC R6 size (AA) NiCd or NiMH cells are 1.2V nominal, constrained by the chemistry. When fully charged, they show a ~1.5V voltage, so the two in series can reach the 3V noted in the SM. These cells cannot be replaced with lithium batteries, even with matching size/form (i.e., "14500") without changing the related circuitries, for the lithium cells being 3.7V nominal.
(NiCd cells are also still available - search)
Share this post
Right. Sorry read that in a hurry. Characteristics of AA cells are fairly straightforward. You could even put in a normal alkaline AA except for the fact that it's real pain to have to replace when they run out.
Share this post
Thanks for the replies!
Those telephone batteries look right.
Why would I need those tabs welded to the contacts?
Share this post
If the batteries are in sockets, then certainly there is no need for the tabs.
I have not yet seen the inside of this particular model, and assumed the batteries are soldered to the main board (like the back up cells in many different devices).
If you have some spare minutes, I would love to see a couple of good photos of the board.
Share this post
Oh!  I get it.  This board has battery "coffins" built into it with typical contacts and a spring inside of each.  I closed it up for now, but as soon as I get a pair of fresh batteries, I'll open it again and photograph and post the innards.
Thanks for the help!
Share this post
Create an account
Register a new account
Sign in
Sign In Now
