Sony Insider Forums
louisw
Sony Net MD MZ-NE810
Hi
I need help
I have Sony Net MD MZ-NE810 and windows 10
Windows 10 doesn't detect MD
Also, I tried some drivers but not working
Any solution?
Please let me know
Share this post
hmmm
i used RH910, and win10 detects it immediately, no driver required.
have u tried installing SS4.3?
Its available on torrent.
Share this post
FORGET TORRENT!!!! The only reason one of you has it working and the other does not, is that there are two flavours of Windows. 64-bit Windows you will need to replace the naturally-installed driver with the 64-bit one in our downloads section. 32-bit Windows it will work out of the box.
Share this post
my win10 is 64bit. last time i checked the download section, i wasnt successful, coz maybe there is a glitch or something, the download always failed halfway. so i had to resort to different method. if the download is working, i dont see any reason to go hunting at torrent.
thanks.
Share this post
7 hours ago, sfbp said:
The downloading failed, or the installation?
the download fails to even start, it always timed out.
Share this post
Oh, that's odd, I thought you said "halfway"? Anyway I just tested and it downloads perfectly. Maybe your antivirus software is making it impossible for the machine to receive a file of type "exe".
Share this post
err, i mean the download windows pops up, but never show progress, then soon after it said download failed. To be honest I havent try again since i already got the files tho... it might be just a fluke in the network connection.
anyhow... i didnt use SS that much, i mainly record directly from line in.
Share this post
On 4/20/2017 at 10:19 PM, louisw said:
Hi
I need help
Any solution?
Please let me know
Hi Louisw,
If you search the Sony Insider Minidisc forum thoroughly, you will find the solution to your problem. The main issue is that Windows 10 does not allow the installation of unsigned drivers (especially with the latest update), and the NetMD drivers are of course unsigned. You have to go to the advanced startup menu and disable the signing of drivers, install the NetMD driver and it is will work after that. Here is a link explaining the process (use option 2): https://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/. Good luck! Let me know if you have any more problems!
Share this post
Create an account
Register a new account
Sign in
Sign In Now
