dfist45
mz-n505 erasing discs
5 posts in this topic
Posted (edited)
I have a sony mz-n505 type r netmd recorder.
when using sonicstage to transfer new music to the minidisc this music has no sound and eject and reinserting  the disc shows as blank.
editing the track data or naming the discs also cause the above blank disc problem
also using the recording function on the player also erases the discs after ejecting and reinserting
on my laptop i have sonic stage 4.3 and the 64 bit drivers on windows 10
any help is appreciated
Edited by dfist45
changed title and post because i think the problem is player related
Share this post
Busted overwrite head. Standard problem. Have to fix it or throw the machine away.
Share this post
Ok, What does "fix it" entail.
it works fine as a playback machine and I'm ok with only using as a playback only machine
Share this post
all it takes is for someone to hit the track mark button and the disk is blank.
Usually the ribbon cable cracks. Unless you have extremely good eyesight and an extremely steady hand with a soldering iron, I think this project is not for you.
Better to buy something else.
Share this post
And the something else will be cheap : around 20-30$ for a  similar (same generation) unit.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
