Sony Insider Forums
kris01
MDS-JA555ES strange problem
Hi
Recently I got MDS-JA555ES. Previous owner didn't care much about it  so it visible on the front  panel but also didn't use it. Total play time is about 220 hours and only 3 hours for recording.
Today I noticed strange thing. Power is on, display is working, seems it is playing but every button is inactive. I can't even switch it off or eject minidisc. I had to remove plug from mains.
I checked all easily accesible connections.
Could it be temperature and humidity problem? It is so hot.
Share this post
Damned, And the problem occur on the ultimate unit... NGY or sfbp will be more helpfull than me but as the previous owner did not use the unit that much, the front panel could have dust or contacts problem inside.
Share this post
More likely something got bounced around in transit, and finally came loose with use. I'm guessing the ribbon cable between the front panel and the rest of the machine.
Share this post
If this is the ribbon cable, it look like something that can easily be fixed. We cross fingers for you kris01. Take pictures if you do not find the problem.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
