Sony Insider Forums
Sign in to follow this
chri5
Transfer music from MD to PC
Do you really need the mz-rh1 to transfer recordings on a MD to the PC?
Why not use the optical output that is available on a number of minidisc decks to the PC for a perfect copy of the recording?
Share this post
Well, sure - but if the recordings are hundreds of hours in length..... it's going to take you.... uh ... hundreds of hours.
Been there, done that.
Having said that, your method is the ONLY way to recover NetMD-created disks. By design :)
Share this post
So if I recorded something live with a mic on my NetMD, I can't transfer it back to the PC via SonicStage? But can via optical?
Could I use SonicStage to transfer it back with the MZ-RH1?
Just trying to get my head around what can and can't be done before I search for a MZ-RH1.
Share this post
Yes, the RH1 will allow you to do what you want. When I say "NetMD-created" i mean the tracks have been transferred to the MD using USB and NetMD (as opposed to HiMD).
But no other NetMD-enabled unit (none of the other HiMDs either) will allow you to transfer FROM the disk.
However (just to complicate things) generally speaking you CAN transfer from any 1GB disk or reformatted legacy disk (to HiMD specs) using the USB link. Simply NOT the SP/LP2/LP4 formats ("legacy"), except with the RH1. There are more restrictions but if you follow our advice(s) you won't run into them.
So you could buy any HiMD device (that has USB) and use a microphone and (as long as the disk is HiMD formatted) transfer the tracks to the PC.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
