Sony Insider Forums
Hi again!
I just purchased this MZ-R2 unit off eBay and still waiting for it to be delivered later this week. Before it gets here I thought about doing some advanced research about it.
Per seller, it displays the error message (see photo) when an MD is inserted. I think the seller is most likely just a reseller, who buys stuff from garage or estate sales, thrift stores, etc. an then resells them on eBay, Craigslist, etc., so they do not have a deeper knowledge about the unit.
I have read something that this model would read factory recorded artists minidiscs smoothly but it has issues playing or even loading any personal type recorded minidiscs.
Is it just a file format issue being an older model of player/recorder? Does anyone know how to fix this issue?
Thank you.
Share this post
The unit can read any SP (standard 292kbps) recording . Do you clean the lens ? Try also a new MD.
Share this post
Thanks, Philippe.
I will try that when the unit arrives here.
Share this post
There are "cleaning MD discs" but any gentle & smooth use of a Q-tip with isopropilic alcool will do.
  • Thanks 1
Share this post
Hi Philippe!
I got the unit yesterday. It did play back a pre-recorded disc. But it cannot read/play any of my own discs with recorded tracks using SP (recording via optical connection).
Plus, there are other issues - I had to press lightly on the cover for it to be able to play back a pre-recorded disc and the remote that came with has the metal part of the headset plug stuck so I cannot insert my own headset.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
