Wormfingers 0 Posted April 24, 2019 Report Share Posted April 24, 2019 Hi everyone! I just found my old Sony MZ-R35 player after 15 years. It is in decent condition, but some of the controls on the unit do not work (volume, pause, mode, display). The remote that came with it can control Volume and Pause but not the Play Mode or the Display. Would the remote of later units - like the RM-MZR50 or RM-MZR55 - be able to achieve that? If you know other remotes that could control the Play Mode and the Display for the MZ-R35, please let me know. Thanks in advance. Quote Link to post Share on other sites
sfbp 8 Posted April 24, 2019 Report Share Posted April 24, 2019 First off, I would try cleaning the contacts on the remotre cable where it goes into the unit. You may want to simply disturb the "nice" shiny gold surface by scratching with a very sharp knife. Then I would double check battery voltages and see if there is a voltage drop between the battery and the unit. Bad connections. Finally, I would test and see if it works when plugged directly into the mains charger. If it does, it's just possible that your batteries need replacing. Quote Link to post Share on other sites
Wormfingers 0 Posted April 24, 2019 Author Report Share Posted April 24, 2019 28 minutes ago, sfbp said: First off, I would try cleaning the contacts on the remotre cable where it goes into the unit. You may want to simply disturb the "nice" shiny gold surface by scratching with a very sharp knife. Then I would double check battery voltages and see if there is a voltage drop between the battery and the unit. Bad connections. Finally, I would test and see if it works when plugged directly into the mains charger. If it does, it's just possible that your batteries need replacing. Thank you for your reply. The issue is not with the remote I currently have (RM-MZR30). The problem is that some of the buttons located on the unit stopped working. Some of them can be controlled with the remote (Pause, Volume), but I am mainly interested in controlling Play Mode and Display. Since my remote does not control these functions, I wonder if I could use another remote - RM-MZR50 or RM-MZR55 - that includes these controls. If you know other remotes that are compatible with my MZ-R35 player, I am all ears. Quote Link to post Share on other sites
sfbp 8 Posted April 25, 2019 Report Share Posted April 25, 2019 Now I understand, you don't have the right RM-MC<whatever>. Your best bet is to buy a used MZ-R50 and try. Not worth trying to source the OEM remote. This page may be helpful. It does seem that anything up to and including R37 is DIFFERENT http://minidisc.org/part_Remote_Control_Sony.html Quote Link to post Share on other sites
Wormfingers 0 Posted April 25, 2019 Author Report Share Posted April 25, 2019 Thanks! I had already checked that page but it seems that it is incomplete. I found many remote models that are not listed. I guess going with a remote from the RM-MZR line would probably be best. The only function I need is "Play Mode", which seems to be either RM-MZR50 or RM-MZR55. Quote Link to post Share on other sites
sfbp 8 Posted April 25, 2019 Report Share Posted April 25, 2019 Search on here using google. Some one did a guide to remotes. Quote Link to post Share on other sites
Wormfingers 0 Posted April 25, 2019 Author Report Share Posted April 25, 2019 I found a couple of links but the link from atraclife.com is dead and the guide for the LCD remotes points to the forum main page where there is no such guide. Were you thinking of another guide? Quote Link to post Share on other sites
sfbp 8 Posted April 25, 2019 Report Share Posted April 25, 2019 Here you go Quote Link to post Share on other sites
Wormfingers 0 Posted April 25, 2019 Author Report Share Posted April 25, 2019 Awesome, thanks! Quote Link to post Share on other sites
Wormfingers 0 Posted May 3, 2019 Author Report Share Posted May 3, 2019 I purchased a RM-MZR55 remote and it works perfectly with the MZ-R35 recorder! Quote Link to post Share on other sites
sfbp 8 Posted May 3, 2019 Report Share Posted May 3, 2019 Great to know! Quote Link to post Share on other sites
