Sony Insider Forums
Sony MDS JE510 unusual eject problem
This appears not to be the normal ejection  problem
When i insert a disk it displays TOC reading for some time, displays eject and then ejects the disk
If I heat the disk unit with a hairdrier for 30 seconds then it is usually possible to read and write disks.
Some background
The player hasn't been used for several years but worked well prior to storage in a dry atmosphere
I tried to find the drive belt to see if it needed replacement but couldn't find it.
Hoping someone can help
  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I think I'd be careful with the heat otherwise some of the components are going to distort!
Note for read, this is a laser-only operation and this is on the underside of the disk (pointing up). The "head" you can see is the overwrite head and this will drop to the surface if a write operation is needed - writing audio data or updating the TOC.
At this point a clean and careful regrease of the sled rail would be my starting position. See here:
Posted (edited)
Thanks kgallen
Had a look but mine is spotless and has been in my possession since new
I tried putting a drop of Singer sewing machine oil on the top sled and using a cotton bud to clean the screw thread (at least it looks like one) underneath. No difference
I have included two videos. one shows moving the head when in setup mode and the other shows a minidisc being inserted and rejected. At around 9 seconds you can see the attempt to move the head.
Edited by Ragodin
Videos not good enough, too big
I think your videos got truncated to 7secs. But either way I'm a little stuck now (doesn't take much!).
In Service Mode can you work the sled back a forth a few times to ensure it's running smoothly? Maybe you already did this after applying the oil (risky, I'm sure you were careful!).
This must be a mechanical thing with the heat unless there is a bad contact that makes when heated up slightly (unlikely I guess!). Clutching at straws!
My only other suggestion before @NGY saves the say is the 'ole ribbon cable trick, but you're not having the same issue as I had at the time. But I don't think you should be using that hairdryer any more!
Before we take any further steps here, please do consider this advise from @kgallen:
Even if this is that infamous "all metal" mechanism, it has some delicate plastic parts - the loading gears and the OWH to mention at first place.
Now, back to the issue:
Generally this is the symptom when the drive cannot read the disc's TOC, for a reason - that can be a single one of many possible, or multifold if you are unlucky.
Do you get the "DISC ERROR" message, before it ejects the disc? (If you do, see some hints here, for what to check first). If you don't and the deck just spits the disc without reading it then we probably face a another issue. To step further ...
... it would help us a lot if we could see the load/read/eject sequence in full length.
Nevertheless, I see on the second video, that in SM you can FF and FW the sled without any problem. This is good news, and shows that at least your sled mechanism is OK. The problem probably lies with the loading mechanism, whether or not the drive properly senses the loaded disc. But no guessing - let's see some more information first.
Thanks guys
Quick response before I redo the video
I don't get any error message it goes straight from TOC reading to eject. I guess the reason for this is that the reading head seems to get stuck and moves a very short distance before returning to its start position
OK, that clarifies.
Please tell me then, when you moved the sled back and forth in SM, was it only possible after "heating" the drive, or you were able to do it just at plain room temperature? If the latter, then I am leaning towards it is a sensor issue.
33 minutes ago, Ragodin said:
Thanks guys
Hmm - isn't that a normal event? Going to start, moving in a bit, then back to outside........... the failure you then see being from what it found (or in this case failed to find).
(don't take any notice of me, it's so long since I had one of these apart I can't even remember if it goes inwards like a CD, or outwards from the centre).
Preamble and TOC is on the inside near the spindle. Disc reads inside to outside. (Below diagram not to scale on the "area" annotations.)
But I would agree with your earlier assertion Stephen, that reading the TOC is very little movement of the sled, The TOC is relatively very little data so can reside on a small number of tracks even on the small circumference of the inner spirals of the disc.
For the OP if technically minded, see this "technology primer": http://minidisc.org/manuals/minidisc_training.pdf
Gentlemen, do we have some "hidden" history of this thread you are referring to? I can't see anything before the OP's post from yesterday. Or, are you referring to another thread? How can we then link this thread to that one or to its "missing history" (if existed)? Would be great to keep all related information together, not only for present troubleshooting session, but for future readers too. The 510 is still a very popular machine for some reason, regardless of its multiple issues that were mostly eliminated from later models (beginning with the 520).
NGY The ability to move the sled in SM did not require heat.
The videos attached hopefully will help
Also the sled didn't move this time at room temperature.
SM info.
FBIAS  head moves across the disk
CPLAY MODE head moves to centre
CREC MODE head moves to centre
DTRAK CHECK head in the centre
Scurva CHECK Focus On
Manual Command ON OF OF
Don't know if this helpful - but always hope
No, it's just I'm getting the hang of reading into Stephen's obscure comments and trying to piece together what he's getting at!
Perfectly possible I got hold of the wrong end of the wrong stick.
All we succeeded to do was disrupt the thread. My apologies! Nothing more to see here!
Please continue!
IMPORTANT: May I add urgently here that you do not look anywhere near a laser where there is a chance it could be emitting. Looking into the INVISIBLE BEAM CAN DAMAGE YOUR EYES.
No, you are fully right - thanks for the addition.
I was going to write a similar disclaimer myself, but I was busy trying to describe the check process itself as percisely as I can. Then as I have been working on multiple tasks the same time (as usual) with this one being only one of them, I simply forgot about it when I returned to my disrupted previous task.
Nevertheless, I honestly do hope that anybody who dares to open a minidisc (CD, DVD, etc., laser beam emitting) device for repair is fully aware of the risks of the laser radiation (not to mention those warning stickers inside these machines). And not only the laser but the live AC power contacts as well, and so on. I cannot be held responsible for any accidents if others completely ignore (or simply "dummy" enough not knowing about) such trivial precautions. And honestly, if I had to begin all my technical posts with such a warning, it would take more time just to write all that stuff down again and again than I would/could normally spend on dealing with the problems themselves.
I hope nobody considers this "ignorance", but here it is then, for now an ever: NODOBODY OPEN an MD device if you are NOT FAMILAR with all these risks and NOT EDUCATED to do such a repair!
Maybe we should create a sticky on this, and from then and on we can focus on the real stuff.
- o -
EDIT: for the sticky and/or for those who want to have more information on laser safety. (Also here, even if "less official".)
A few quotes on Class 1 lasers (like the ones in MD gear):
FDA Class IEC Laser Product Hazard Product Examples
I 1, 1M Considered non-hazardous. Hazard increases if viewed with optical aids, including magnifiers, binoculars, or telescopes.
  • laser printers
  • CD players
  • DVD players
"Class 1
CLASS 1 LASER PRODUCT
A Class 1 laser is safe under all conditions of normal use. This means the maximum permissible exposure (MPE) cannot be exceeded when viewing a laser with the naked eye or with the aid of typical magnifying optics (e.g. telescope or microscope). To verify compliance, the standard specifies the aperture and distance corresponding to the naked eye, a typical telescope viewing a collimated beam, and a typical microscope viewing a divergent beam. It is important to realize that certain lasers classified as Class 1 may still pose a hazard when viewed with a telescope or microscope of sufficiently large aperture. For example, a high-power laser with a very large collimated beam or very highly divergent beam may be classified as Class 1 if the power that passes through the apertures defined in the standard is less than the AEL for Class 1; however, an unsafe power level may be collected by a magnifying optic with larger aperture. - Class 1 laser diodes are often used in optical disc drives"
"There is also the optics of the laser assembly to consider as they are collimated to focus at a very close distance (the distance to the surface of the CD). Anything more than an inch or so away from that and the beam is so diffuse it couldn't hurt you (as the beam spreads out, the wattage is the same, but its dramatically spread out of a much larger area, so the intensity is much lower). But, if you don’t know the optical setup then its better to just play it safe"
Conclusion: see the very last sentence above, in italics.
Good stuff.
This is the first post I think I've read on this forum (in my short time here) where the interlocks are effectively defeated and expose the beam so I think our comments above are worth stating at this point.
OK, if this was the first one, then the post is deleted. You may want to delete your quote too. I won't hold ANY responsibility. Thank you.
Side note: tons of posts exist on this forum where service mode operations described. Laser radiation is possible in service mode, even if one does not intentionally "defeats laser interlocks".
Please continue!
Nah, I'm the "higgerunt" one here. Guilty as charged.
BTW I think it's probably fair to say that at sub 1mW (READ MODE) these things are safe. But of course a completely maladjusted or random failed circuit might be able to churn out more.
The time you really need to be careful (with an already-functioning OP laser) is when the power is 10x that, which it is in WRITE MODE. Fair? Also pointing out that you may eventually likely blow the laser if you leave it on for too long in the service mode write mode. Remember in write mode, you are heating things up bigtime - what if that was your eye? Sort of analogous to frying certain parts of you in a microwave, even though microwave ovens are pretty safe.
The MD lasers run at 780nm which is just barely into the infrared spectrum. It's the coherence of a laser which makes it so dangerous.
The NHS advert currently running on uk tv about stroke F.A.S.T (and calling 999) pictures someone's head catching fire - my immediate thought was "MD Laser".
You guys were so helpful at the start which I really appreciated. However the thread seems to have gone off at a tangent.
I tried cleaning the ribbon cables as suggested with no difference in the result.
I guess that I should write off my old mini-disc machine as there is no one round here who does repairs
I wouldn't say that yet. You seem to have some knowledge and are happy to work safely inside the machine so if you make some careful step by step checks then you may open up some ideas or fix the problem.
We don't have a definitive answer for you. But at this point I would assume a simple problem needs tracking down since you know the machine works.
Like: have you tried different disks. Is there any difference across brands? If you carefully apply a little pressure (instead of heat) to parts of the frame does that change anything? Does the disc look like it is spinning smoothly? Is the disk seating properly? Are there different noises under different conditions of above? When you did the heating (which I advise no more), which parts were you heating which had an effect?
Feed us with some information then we might have other ideas. We don't have the machine in front of us, you do. Just treat it gently and try ideas carefully. Otherwise it will become a piece of scrap.
Kevin
