ML_SONY.DLL - Further development
bergmarmot
Hi Otiasj,
it is almost a year ago since the latest release of the winamp plug-in, which by the way works perfectly. Nevertheless there is still space for improvements and for me that is the option to play the transferred MP3's within winamp itself. Currently the files (or the header) seems not to be exaclty as they should be and therefore can not be playbacked. This is not an problem on the MP3 player (NW-HD5) as they can be playback, but in winamp this still is not possible.
If you need help to get it programmed please it know to the community instead trying to get this solved all by yourself alone. Together we are stronger :lol:
I am looking forward to a version that solved the aboved addressed issue.
Kind regards,
Bergmarmot
Edited by bergmarmot
hello Bergmarmmot,
Sorry I did not see your post, has I was only watching the ml_sony thread.
I am working on the new version of ml_sony but It will be a moment until I can add this feature,
You are welcome to implement it!
the source code is on svn in source forge.
The trick for this is to decode the OMA file while playing it.
decoding is easy if you have the correct keycode.
but I have no idea on how to do this while playing...
you probably have to create some kind of input plugin for winamp to stream the file and decode it at the same time.
so if you are willing to help you could start by that!
See if you can find some info on input plugin and how to stream the file!
Let me know if you find some good info!
As you said it will save us some time ^^
