Cover Art
norhady
You should be able to add the album art in SS and it should transfer offer when you move the songs over. if there is no cover art in the folder would dragging and dropping work?
yea.ss works fine but i'm totally want to get rid of ss. i just wanna use simple winamp to transfer my files...
another problem (just an experiment).i already got playlist generated by ss (with cover art work fine) but after i use winamp and click apply, the coverart gone... so i guess, sony_ml didn't generate/update database with coverart...
