N1 beats N10
The 2x download speed of the N10 is great. The overall feature upgrade and the form factor is outstanding. I looked at the N1 and waited, then jumped for the N10. Biggest issue is battery life. That depends on how you plan to use it. The built in battery is very good, but will not last as long as the N1. If you plan to go on long trips, you will need the battery pack and a charger. I have travelled up to a week without a recharge. The look and feel of the N10 is superior. Perhaps the best advice is for you to wait until you can compare them side by side.
