poorlyconditioned Posted November 16, 2004 Report Share Posted November 16, 2004 Does anyone know how to transfer from Wav to HiSP using SonicStage? I use "Import" to get an (unprotected) WAV file into SonicStage. But whenever I try to transfer, it gives me only choices: 48, 64, or 132kbps. In the past I wrote the WAV to a CD and used SimpleBurner to copy to the MD. Is there any way around this? Thanks, Richard Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted November 16, 2004 Report Share Posted November 16, 2004 Right-click the track in the library, select "convert format" then select "openmg audio (atrac3plus)" and choose 256 kbps from the dropdown list. You can do this with any track in the SS library, btw. You might also consider reading your manual. Quote Link to comment Share on other sites More sharing options...
