Entering Service Mode On A Hi-MD Player
This was a great post made by WhEdGe that was lost when worms tried to destroy the board. I was able to recover it, but unfortunately, I'll have to repost it all.
Hello People,
entering service mode is possible by following this instruction:
Set the "HOLD" switch on.
While holding down the GROUP key instead, enter the key sequence:
i.e. FF FF REW REW FF REW FF REW PAUSE PAUSE
Release all keys.
If you have successfully entered service mode, the display will alternately display the firmware version in the left display and a screen with all LCD segments lit at about half second intervals.
Thats it!
Dont change any settings unless u know what u are doing!!!!!!!!!!! Leave the service mode by removing the battery!!!
This will only be important if somebody has figured out how to change the settings for upgrading ur device. In the moment it is of no use!!
a procedure similar to this http://www2.minidisc.org/mzr700_to_mzr900.html has to be found!
i guess settings of mz-nh1 or mz-nh900 have to be compared with the settings of mz-nh600 .... a service manual could also help!
i really would love upgrading my device
  • Replies 186
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Originally posted by The_Stamp:
heh, while doing this.. i noticed something funny... theres a row of vaules... each one being "1c" then the last one is "cc" righting down the values.. im noticed a LOT of "cc" entries... perhaps that means disabled... anywho.. heres the audio category entries.
110- > cc (ignore, every category has this entry) edit: this is the section title
111- > 1c
112- > 1c
113- > 1c
114- > 1c
115- > 1e
116- > 0e
117- > cc .... (mp3?)
and theres 6 different bitrates for atrac3! what a coincidence.... could the 117 be the mp3?
i also noticed that all the categories have a 100 cell, but each one has the entry "cc" so im just going to assume that that is just a dummy field.
Then a follow-up post:
ok guys! heres the first batch of numbers... this is under the 9th category "Design"
The different categories are:
0-Manual
1-NV
2-Power (wont be touchin that tongue.gif)
3-Audio (all the entries is in the post above)
4-MD1
5-Hi-MD1
6-Hi-MD3
7-NORADJ
9-Design
ok, hi-MD 1 and HI-MD 3 im guessing are the formatted and gig discs entries. Note that every new tens digit appears to be a label for the settings that follow it.
I did "Manual" and "design" first, because if there would be settings, it would be in one of two categories! anywho, we'll start off with "9-Design"
110 MD1
111 0f
112 11
113 84
114 9f
117 cc
118 cc
130 HiMD3
131 3b
132 0f
134 58
135 cc
136 cc
137 cc
138 cc
140 LD OFF
220 All Adj
221 cc
222 cc
223 cc
224 cc
230 HiMD1
231 cc
232 cc
233 cc
240 HiMD3
241 cc
242 cc
243 cc
244 cc
250 Other
251 cc
260 Adj NG
261 00
262 00
263 00
264 00
300 OTHER
320 TEPeak
321 cc
322 cc
350 OfSet
351 cc
370 For Pb
371 cc
372 cc
400 ChkErr
410 SrvDat
411 PB*28
412 00
413 15
414 00
415 cc
416 cc
417 cc
420 StpFac
421 08
422 00
423 DH0002
424 DL0000
425 SA3V22
426 01
427 00
428 00
429 00
900 Power
910 Power
911 46
919 cc
Enjoy!
edit: here is the entries for 0-Manual.
100 MT
110 NV
111 cc
112 no clok
113 40
114 00
120 LASER
121 0f
122 9f
123 cc
124 3b
130 TEMP
131 19
132 18
133 e0
200 SET
210 DiscPr
211 32
212 1e
213 93
214 28
215 26
216 74
217 15
218 20
219 cc
220 AdjUID
221 31212
222 00
223 1207
300 OTHER
310 cc
311 ff
312 3f
313 cc
900 LINE
910 MngFlg
911 00
912 00
920 Other
921 00
MAN I WANT TO DO SOMETHING TO THE LINE SECTION!!!!!
And another reply after this from the fellow:
instructions in service mode -
press up to go into the entries section
press up and down to scroll the different categories
press right once to select that category
press up and down to scroll the different sections (the 100's)
press right once to select a section
(at this point, you can just keep press right and left to back and forth the entries)
press up and down to scroll the different sub-sections (the 10's)
press "STOP" to go back to the start of a sub-section, where you can scroll the sub-sections.
pressing stop again will go back into the sections.
pressing stop again will go back into the categories.
pressing stop again will go back into the main flashy screen.
Originally posted by xispe:
NH700 european version values:
in the flashy display:
005
Ver 1.100
3 Audio:
100 - CC
110 - CC
111 - 1C
112 - 1C
113 - 1C
114 - 1C
115 - 1E
116 - 0E
117 - CC
120 - CC
121 - 15
122 - 1C
123 - CC
124 - 1C
130 - CC
131 - 00
9 Design:
110 - MD1
111 - 0F
112 - 11
113 - 84
114 - 9F
118 - CC
130 - HIMD3
131 - 3B
132 - 0F
135 - CC
136 - CC
137 - CC
138 - CC
140 - LD OFF
220 - ALL ADJ
221 - CC
222 - CC
223 - CC
224 - CC
230 - HIMD1
231 - CC
232 - CC
233 - CC
240 - HIMD3
241 - CC
242 - CC
243 - CC
244 - CC
250 - OTHER
251 - CC
260 - ADJ NG
261 - 00
262 - 00
263 - 00
264 - 00
300 - OTHER
320 - TEPEAK
321 - CC
322 - CC
350 - OFSET
351 - CC
370 - FOR PB
371 - CC
372 - CC
400 - CHKERR
410 - SRVDAT
412 - 00
414 - 00
415 - CC
416 - CC
417 - CC
420 - STPFAC
422 - 00
427 - 00
428 - 00
429 - 00
900 - POWER
910 - POWER
919 - CC
0 Manual:
110 - MT
110 - NV
111 - CC
112 - NOCLOK
114 - 00
120 - LASER
121 - 0F
122 - 9F
123 - CC
124 - 3B
130 - TEMP
131 - 19
132 - 18
133 - D7 (laugh.gif it's almost winter in here ahahah tongue.gif)
200 - SET
210 - DISCPR
212 - 1E
214 - 28
219 - CC
220 - ADJUID
300 - OTHER
310 - CC
311 - FF
312 - 3F
313 - CC
900 - LINE
910 - MNGFLG
911 - 00
912 - 00
920 - OTHER
921 - 00
Ok... leaving service mode now, i hope my unit still works
EDIT: rocking  . At least still playing.
The lines containing the emoticons mean that the values differ from the posted ones for the nh600
n0g0THEf0li0 stepped up to the plate and hit a home run with this one:
SONY MZ-NHF800
Service Menu
Activate "Hold Switch"
Fw Fw Rw Rw Fw Rw Fw Rw PAUSE PAUSE
[NOTE: Stop button Takes to previous menu, throughout]
[NOTE: *** denotes three digits scrolling upwards in increasing value from 0-9 proceeding through A-F]
004 Ver 1. 100
Vol Down Takes to: 0 AdjFFF [Any button]: 0 Fnshd!
Rew Takes to: Nothing
Fw Takes to: 012 1 0000 [Whatever this is, Vol Up seems to modify it]
Vol Up Takes to:
[NOTE: Vol Up Scrolls to next Cat, Fw to 100's Class, Vol Up to Next 100's class, Fw to 110's class, Vol Up to Next 110's class]
[the values in the 110's class seem to be changeable via the Vol Up button]
0 Manual
100 MT
110 NV 110 ***SCC
111 ***SCC
112 NoClok
113 ***S50
114 ***S00
120 Laser 120 ***SCC
121 ***S0F
122 ***S9F
123 ***SCC
124 ***S3D
130 Temp 130 ***SCC
131 ***S19
132 ***S19
133 ***SD7
200 SET 200 ***SCC
210 DiscPr 210 ***SCC
211 ***S30
212 ***S1E
213 ***S8B
214 ***S28
215 ***S24
216 ***S6D
217 ***S14
218 ***S03
219 ***SCC
220 AdjUID 220 ***SCC
221 040405
222 000000
223 011795
300 Other 300 ***SCC
310 LED 310 ***SCC
311 ***SFF
312 ***S3F
313 ***SCC
900 LINE 900 ***SCC
910 MngFlg 910 ***SCC
911 ***S00
912 ***S00
920 Other 920 ***SCC
921 ***S00
1 NV
100 VNV 100 ***SCC
110 ChkChg 110 ***SCC
111 Pw0069
112 Sr0031
113 SS00CC
114 CS0730
900 NV 900 ***SCC
910 NV 910 ***SCC
911 ***SCC
912 ***S00
913 NV OK
914 ***S00
915 ***SCC
916 ***SCC
917 ***SCC
918 ***SCC
919 ***SCC
920 Patch 920 ***SCC
921 PV1.1B
922 ***S00
923 ***S00
924 B41100
930 State 930 ***SCC
931 ***SFF (Disc Icon Also Lit)
932 NoClok
933 ***S00
934 ***SCC
940 Info 940 ***SCC
941 ***S50
942 ***S00
943 ***S00
944 ***S00
2 Power
100 cHECK
110 PWRCHK
111 AD CC
112 AD 01
113 AD 01
114 AD CC
120 V_Moni
121 AD 83
122 AD 00
123 AD 90
124 AD 1E
130 ChQcMd
131 AD 00
132 AD 00
133 AD CD
140 Charge
141 AD FD
142 AD CC
200 Adjust
210 PwrAdj
211 AD 28
212 AD 38
213 AD 2B
214 AD 68
215 AD 68
216 AD 73
217 AD 73
218 AD B3
219 AD C4
221 AD D8
222 AD EB
223 AD 16
224 AD 11
225 AD 20
226 AD 43
227 AD 7F
228 AD B7
229 AD 15
231 AD 30
232 AD 97
233 AD 97
240 VBsAdj
241 AD 6F
242 AD 2C
243 AD 61
244 AD 30
250 ChrgLi 250 ***SCC
251 ***SCC
260 ChrgNi
261 AD 71
262 AD CC
263 AD CC
264 AD CC
265 AD CC
266 AD CC
267 AD CC
268 AD CC
300 OprtIC
310 Spinch
311 AD 00
312 AD 00
320 Yuzu
321 AD 00
322 AD 00
330 FFCLR
331 AD 00
400 ChgChk
410 Li-ion
411 AD CC
412 AD CC
413 AD CC
414 AD CC
415 AD CC
416 AD CC
417 AD CC
418 AD CC
419 AD CC
430 Other
431 AD CC
3 Audio
100 Audio
110 Au Pb
111 ***S1C
112 ***S1C
113 ***S1C
114 ***S1C
115 ***S1E
116 ***S0E
117 ***SCC
120 Au Rec 120 ***SCC
121 ***S15
122 ***S1C
123 ***SCC
124 ***S1C
130 AGCPrm 130 ***SCC
131 ***S00
4 MD1 (Partial List, Will Finish at Some Point)
100 Grv
110 SrvOFF
111 ***SCC
112 ***S0D
113 ***S14
114 ***S02
118 ***S0A
120 ***SDD
121 ***S06
122 ***SFF
123 ***S00
124 ***SFE
125 ***S29
126 ***S00
127 ***SF5
128 ***SEE
130 ***SCC
131 ***SFE
132 ***SF3
133 ***S00
134 ***S2D
136 ***S0F
137 ***S0D
138 ***S12
139 ***S1A
140 ***SCC
141 ***SF2
142 ***S00
143 ***S00
144 ***S1C
145 ***S2F
146 ***SCC
147 ***SCC
149 ***SFD
151 ***S04
152 ***S00
154 ***S09
157 ***S97
158 ***S01
159 ***S97
200 Lpit 200 ***SCC
210 ***SCC
220 ***SDD
221 ***S09
224 ***SFE
225 ***S18
226 ***S00
228 ***S1B
230 ***SCC
232 ***SFF
236 ***S0D
237 ***S0B
238 ***S15
240 ***SCC
241 ***SF0
242 ***S00
243 ***S00
244 ***S29
245 ***S19
251 ***S07
300 Hpit 300 ***SCC
310 ***SCC
311 ***SCC
312 ***S0B
313 ***S14
314 ***S02
320 ***SDD
321 ***S0A
324 ***SFE
400 x4Writ
500 x2Writ
600 Dummy
700 AutCom
800 SERVO
900 OP Adj
5 HiMD1 (Skipped for Now)
6 HiMD3 (Skipped for Now)
7 NORADJ (Skipped for Now)
9 DESIGN
100 Laser
110 MD1
111 ***S0F
112 ***S11
113 ***S84
114 ***S9F
117 ***SCC
118 ***SCC
130 HiMD3 130 ***SCC
131 ***S3D
132 ***S0F
134 ***S5E
135 ***SCC
136 ***SCC
137 ***SCC
138 ***SCC
140 LD OFF 140 ***SCC
200 AllAdj
220 MD1 220 ***SCC
221 ***SCC
222 ***SCC
223 ***SCC
224 ***SCC
230 HiMD1 230 ***SCC
231 ***SCC
232 ***SCC
233 ***SCC
240 HiMD3 240 ***SCC
241 ***SCC
242 ***SCC
243 ***SCC
244 ***SCC
250 Other 250 ***SCC
251 ***SCC
260 Adj NG 260 ***SCC
261 ***S00
262 ***S00
263 ***S00
264 ***S00
320 TEPeak 320 ***SCC
321 ***SCC
322 ***SCC
350 Ofset 350 ***SCC
351 ***SCC
370 For Pb 370 ***SCC
371 ***SCC
372 ***SCC
400 ChkErr 400 ***SCC
410 SrvDat 410 ***SCC
411 ***S09
412 ***S00
413 ***S16
414 ***S00
415 ***SCC
416 ***SCC
417 ***SCC
420 StpFac 420 ***SCC
421 ***S00
422 ***S00
423 DH0010
424 DL0001
425 SAFFEE
426 ***S00
427 ***S00
428 ***S00
429 ***S00
900 Power 900 ***SCC
910 Power 910 ***SCC
911 ***S48
919 ***SCC
It's easier to see in another format:
http://www.ncoleman.com/files/servicemenu_mz-nhf800.txt
And then came back a few innings later with a grand slam:
Aoix came around to join in the fun as well! Here's his contribution:
hello,
I'm french.
To participate at the futur hack of our HiMD  , I list all values in the service mode on my european MZ-NH600. You can see the text file here.
If you have a NH900 or NH1, please enter in service mode...  because we haven't yes values for this models.
(sorry if my english is bad  )
And with that, I reintroduce this thread to the public and let's resume hackin'!
Thanks xispe,
(excuse me for the spelling mistake in your name on my last post.)
On the older Md player, we can increase the power of output with the hack?
If it's possible, the single solution is that MD player had operational amplifier with numeric control gain. and that this gain is available in service mode. I don't sure. dry.gif
The second solution is to change resistor physically in MD if the gain haven't numeric control.
But I think that it's hard...
Hi xispe,
Shermy: you have a nh900 right?
so... post your machine values
I want to, I really do, but I'm Scared!!
I've read in some other posts or perhaps on the www.minidisc.org site that people have lost functionality of their machines by accidentally hitting something while in service mode.
Is this kind of like changing the registry on your computer...As long as you have a good idea of what your doing, you should be ok?? Of course, I really don't have a good idea of what I'm doing. Also, I only have one MD recorder, and I use it for recording practice sessions and performances almost daily.
I would still like to know if defaults can be changed by making alterations in service mode. Specifically, I would like to change the default recording volume to manual rather than AGC. I recently wasted 3.5 hours of recording due to this.
I did the service mode hack for the R500 a while ago and it added the program playmode to the unit. I notice that on the NHF800, both the unit and remote have the 'PGM' bit on their LCD screens. Would it therfore be hypothetically possible to add that functionality to the 800 (and possibly lower models)?
Hi. these are settings in my MZ-NH900 from europe
MODEL nh900
REGION europ
003
VERSION 1.100
0 Manual======================
100 MT 100 MT
110 NV 110 ***SCC
111 ***SCC
112 NoClok
113 ***SA1
114 ***S00
121 ***S0F
122 ***S9F
123 ***SCC
124 ***S3B
130 Temp 130 ***SCC
131 ***S19
132 ***S1c
133 ***Se2
200 SET 200 ***SCC
211 ***S30
212 ***S1E
213 ***S8B
214 ***S28
215 ***S24
216 ***S6D
217 ***S14
218 ***SD3
219 ***SCC
221 40405
222 00000
223 09553
300 OTHER 300 ***SCC
310 LED 310 ***SCC
311 ***SFF
312 ***S3F
313 ***SCC
900 LINE 900 ***SCC
911 ***S00
912 ***S00
921 ***S00
9 DESIGN=======================
100 Laser 100 Laser
110 MD1 110 MD1
111 ***S0F
112 ***S11
113 ***S84
114 ***S9F
117 ***SCC
118 ***SCC
131 ***S3B
132 ***S0F
134 ***S5C
135 ***SCC
136 ***SCC
137 ***SCC
138 ***SCC
200 AllAdj 200 ***scc
220 MD1 220 ***SCC
221 ***SCC
222 ***SCC
223 ***SCC
224 ***SCC
231 ***SCC
232 ***SCC
233 ***SCC
241 ***SCC
242 ***SCC
243 ***SCC
244 ***SCC
251 ***SCC
261 ***S00
262 ***S00
263 ***S00
264 ***S00
321 ***SCC
322 ***SCC
351 ***SCC
371 ***SCC
372 ***SCC
410 SvrDat 410 ***SCC
411 ***S00
412 ***S00
413 ***S14
414 ***S00
415 ***SCC
416 ***SCC
417 ***SCC
421 ***S00
422 ***S00
423 DH0080
424 DL0400
425 SA003F
426 ***S00
427 ***S00
428 ***S00
429 ***S00
911 ***S47
919 ***SCC
Edited by bootsy
hey guys... check this one. I have a nh700.
In any of the items if you press the group key, a couple of times, more info is displayed about that item...
for instance:
131
SetTmp 19
132
DspTmp 13 -> NICE ONE biggrin.gif This one is the actual temperature of the DSP. I've put the unit over my leg, and a minute or so later it was displaying 15 tongue.gif
133
DspOfs D7
and so on...
Now at that misterious 220 AdjUID item, heres what you would get
221 YrMnDy CC -> Year, Month, Day ?? My value for this one is 040405 smile.gif Manufacture day ??
222 Serl H CC -> (H = High ?) -> all zeros...
223 Serv L CC -> (L = Low ?) -> this one is nice it changes from model to model.
I've tried to change 223, but with no success, i don't know how to save the value.
EDIT: Don't worry, after messing around lots of time in the service mode my unit is still rocking biggrin.gif
Edited by xispe
Hi,
I update my text file with the bootsy values...
http://aoix.free.fr/himd/compare_HiMD.txt
but I have some questions, bootsy, your model is a nhF900 (with tuner???) it's exist! or it's a mistake and you have a nh900... and can you verify your value 223 (009553) i tink that a extra number.
and a seconde question for xsipe, what is your methode to have the name of each value?? 131, 132... because me, I find only the "hundred" and "ten" values.
Hi people.
Here is the first version of the service mode names and values from my MZ-NHF800 (European Model). There are some intersting things, though one that stands out to me is:
AUDIO #115 which is called 'VolMax' and has the value 1E, which in decimal is 30 and surprise surprise, is the maximum volume level for the unit!
cheers xispe.
I will add more info from other categories if it is needed.
aoix: My AdjUID values are correct, I have double-checked them in service mode and they are definately:
221: YrMnDy CC
222: Serl H CC
223: Serl L CC
edit:
Hang on, I know what you mean. The display shows CC but using the format in your table aoix, I have:
221: 040405
222: 000000
223: 011778
Dave
Edited by Davew
Hi, i corrected my post it was a mistake with that mz-nhf900, but this value 223 (009553) i got 6 digit, also value 221 (40405), 222 (00000), 223 (09553) i got with additional first 0 (i guess that you are skiping that first 0 whitch is always 0??)
Hi people.
Awesome Davew!!
Thanks to bootsy too!!
I'm warming up to getting my values out there. Be patient with me please unsure.gif
Hey Davew, was your beep set to on or off when you went into service mode? The reason I'm asking is to determine the difference between "cc" and "00". Could "00" mean default or "on"? What I'm looking to mod is the default setting for recording. I'd like to have it set to manual rather than AGC. Seeing the following makes me wonder if it's as simple as changing "00" to "cc".
3: AUDIO
100: Audio
110: Au Pb
117: Beep CC
130: AGCPrm
131: WrtAGC 00
Also seeing things like YrMnDy and Clock set to CC lead me to the same conclusions. Am I way off here?
120: Au Rec
121: Lo iMa 15
122: Ho iMa 1C
123: Lo iAt CC
124: SensLo 1C
I promise you will see my values. Just give me some time to build up some courage.
Thanks Shermy, at the moment I am working to expand my info, with more categories and information about what you can edit.
I am 99% sure i had beep set to off when I compiled my list and it seems that most of the audio stuff cannot be changed, but there might be hope yet. As I said, I am working on improving my info, will have that ready as soon as possible, but I have to be careful, what with working in service mode!
Dave
...and it seems that most of the audio stuff cannot be changed, but there might be hope yet.
That's a potential bummer.
Hey aoix, I noticed your beep was set to on, however, you didn't write down the audio values. Have you looked at them? If so, what was your value for the following:
3: AUDIO
100: Audio
110: Au Pb
117: Beep CC
my values of service mode audio menu are
3 AUDIO===============
100 Audio ***SCC
>110 Au Pb ***SCC
>>111 LR1kHz ***S1C
>>112 L 1kHz ***S1C
>>113 R 1kHz ***S1C
>>114 Infi 0 ***S1C
>>115 VolMax ***S1E
>>116 AvlsOn ***S0E
>>117 Beep ***SCC
>120 Au Rec ***SCC
>>121 Lo iMa ***S15
>>122 Ho iMa ***S1C
>>123 Lo iAt ***SCC
>>124 SensLo ***S1C
>130 AGCPrm ***SCC
>>131 WrtAGC ***S00
and i check the "beep". If I have "beep on" or "beep off" in user menu, the value "117 Beep" in sevice mode are the same "CC"
helo, does any body know how to save changes in service mode in menu audio??
I want to change setting 116 AvlsOn ***S0E -> 116 AvlsOn ***S14, these are setting to limit avls. i want to change limit from 14 (0E in HEX) to 20 (14 in HEX).
But i can't save this setting.
Any ideas??
PS. in my mz-nh900 settings in menu audio are also:
100 Audio ***SCC
>110 Au Pb ***SCC
>>111 LR1kHz ***S1C
>>112 L 1kHz ***S1C
>>113 R 1kHz ***S1C
>>114 Infi 0 ***S1C
>>115 VolMax ***S1E
>>116 AvlsOn ***S0E
>>117 Beep ***SCC
>120 Au Rec ***SCC
>>121 Lo iMa ***S15
>>122 Ho iMa ***S1C
>>123 Lo iAt ***SCC
>>124 SensLo ***S1C
>130 AGCPrm ***SCC
>>131 WrtAGC ***S00
Edited by bootsy
helo, does any body know how to save changes in servise mode in menu audio??
It's good question, I test the old method " press pause" but it's dont work... sad.gif (I test to put '0F' to replace the '0E' of AUDIO 116 Avls value)
and I update the text file that compare values (Maunal, Audio and Design) of all peoples.
and also, I update the second text file of all values that I have can read on my NH600.
...and i check the "beep". If I have "beep on"  or "beep off" in user menu, the value "117 Beep" in sevice mode are the same "CC"
Also, nice work at deciphering (or, at least attempting to decipher) all the codes in your service mode .txt files!! cool.gifcool.gif
I hope there is someone that knows how to save changed audio values. I'll be posting my values soon.
Yes! come on! we're gettin' places!
I'm taking AUDIO #115 (VolMax) as an example here (since it seems a fairly safe test value to ..ehem.. meddle with!)
The 2-digit Hex value can be changed using the wheel for the first digit and the 5 way stick (up/down) to change the whole number up or down by 1.
However I can find no way of saving that value to the memory?
The T MARK button moves you to some other editing thing that I don't understand and no other buttons seem to save the new hex value????
But, as you say xispe, we will do it!
Yeah! Dave
Edit:
I have made some minor changes to my listing
some function descriptions in the AUDIO section that will be of use for your table, aoix.
Edited by Davew
