AE86_Racer Posted January 10, 2005 Report Share Posted January 10, 2005 Hey everyoneI recently purchased a used NF520D from a friend. It appeared to be in good condition and it 15 dollars + 5 discs, I thought it would be ok. He assured me it burned before using RealPlayerGuess what, it doesnt.It plays back all teh discs he's given me, but any discs I make dont playback. It acts as if everything went well. But when I go to playback, after 10 seconds it stops playing and starts skipping really badlyMethods tried:new software(Sonicstage, SimpleBurner, RealPlayer 11)codec reinstallcleaning the player head with a Maxell MD-CL cleanerAnything else left to try or should I return the unit as dead?Thanks for all your help Quote Link to comment Share on other sites More sharing options...
Christopher Posted January 10, 2005 Report Share Posted January 10, 2005 Welcome to the forums. That is a pretty damn good deal if the unit is actually functional. What version of Sonicstage are you using? What operating system are you using? Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 10, 2005 Report Share Posted January 10, 2005 more often then not SS's previous versions are to blamehowever have you tried recording via line in at all? does that seem to work? Quote Link to comment Share on other sites More sharing options...
AE86_Racer Posted January 10, 2005 Author Report Share Posted January 10, 2005 Welcome to the forums. That is a pretty damn good deal if the unit is actually functional. What version of Sonicstage are you using? What operating system are you using?←Im running Windows XP Home SP1 I started out in SonicStage 1.5 and them moved up to 2.3. Im running RealPlayer11 and SimpleBurner 2.0 Quote Link to comment Share on other sites More sharing options...
Fat Tires Posted January 10, 2005 Report Share Posted January 10, 2005 more often then not SS's previous versions are to blamehowever have you tried recording via line in at all? does that seem to work?←The NF520D is a USB download only unit. It does not have a line in jack. Quote Link to comment Share on other sites More sharing options...
Christopher Posted January 10, 2005 Report Share Posted January 10, 2005 Im running Windows XP Home SP1 I started out in SonicStage 1.5 and them moved up to 2.3. Im running RealPlayer11 and SimpleBurner 2.0←Upgrade to Service Pack 2. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 10, 2005 Report Share Posted January 10, 2005 ya its free anyways, if you have dialup just be prepared to let it run overnight Quote Link to comment Share on other sites More sharing options...
AE86_Racer Posted January 11, 2005 Author Report Share Posted January 11, 2005 ya its free anyways, if you have dialup just be prepared to let it run overnight←what would SP2 do? Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 11, 2005 Report Share Posted January 11, 2005 (edited) what would SP2 do?←for one it protects your computer from thousands of possible vulnerbilitiessecondly it installs a pop-up blocker in Internet Explorerthirdly it makes WinXP much more stable. A service pack is basically a package of small patches that are applied all at once.If you have WinXP you almost *need* to have SP2you can get it by going to the Windows Update link in your Start Menu or by opening Internet Explorer and clicking Tools > Windows Updateonce on the site click either express or custom, it'll scan your computer for the updates it nees and then all you have to do is click download Edited January 11, 2005 by ROMBUSTERS Quote Link to comment Share on other sites More sharing options...
Christopher Posted January 11, 2005 Report Share Posted January 11, 2005 what would SP2 do?←Aside from what ROMBUSTERS has mentioned, it also upgrades MDAC, JET database and a few other backend applications that Sonicstage employs to run correctly. With SP2, I am assured that those things are not causing the issue in this situation. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 12, 2005 Report Share Posted January 12, 2005 Aside from what ROMBUSTERS has mentioned, it also upgrades MDAC, JET database and a few other backend applications that Sonicstage employs to run correctly. With SP2, I am assured that those things are not causing the issue in this situation.←it also fixes the problem some users experience with a security patch downloaded pre-sp2 Quote Link to comment Share on other sites More sharing options...
AE86_Racer Posted January 12, 2005 Author Report Share Posted January 12, 2005 (edited) Well I installed it and ran a burn session through RealPlayer. No dice, still coughing up bad discs. Should I make an attempt in SonicStage? Ive always been told SOnicStage is the devil so Ive been avoiding it. Should I use it though? Edited January 12, 2005 by AE86_Racer Quote Link to comment Share on other sites More sharing options...
