Huffmann Posted March 8, 2005 Report Share Posted March 8, 2005 Hello,I'm new to the Hi-MD format/software from Sony and I have some trouble with playing and converting (to wave) oma-files that have been uploaded to a server and then downloaded again. The thing is that I'm using a Hi-MD-recorder in a project work to make microphone recordings, and I have to upload the recorded files first to my computer with sonicstage (2.3) and then again transfer them to a central server so that the files can be accessed for other users. The problem when downloading them again, is that something with the rights information seems to be "gone". When trying to play the file in SonicStage, it won't, and SS asks me to connect to the internet to get license information. So I guess the rights information for the oma-tracks are stored on some other location than the sound files on my computer (or something) to deny the files from being accessed from other locations? Is it possible to somehow join this rights information with the soundfiles again on my computer so that I can convert them to another format before transferring them to the server? How should I deal with this in the future..? Thanks for any help! Quote Link to comment Share on other sites More sharing options...
LivingLand Posted May 13, 2005 Report Share Posted May 13, 2005 hi, I'm having the same issue! I'm working on a project collecting audio and need to transfer the files to another computer. Have you had any luck figuring it out yet? LL Quote Link to comment Share on other sites More sharing options...
toxigenicpoem Posted May 14, 2005 Report Share Posted May 14, 2005 No. OMA files are linked to a 'KEY' that you individual pc gets. This is to keep distribution off limits in the OMA format. You will need to convert before transfering. Quote Link to comment Share on other sites More sharing options...
A440 Posted May 14, 2005 Report Share Posted May 14, 2005 If you're using SonicStage 2.3 get .wav converter from Sony. http://sonyelectronics.sonystyle.com/walkmanmc/wav.htmlHighlight the .oma file in My Library, convert it to .wav and all the idiotic rights and keys and DRM are gone. You can then convert it back to .mp3 or any other usable, transferrable format. If you upgrade to SonicStage 3.x, then .wav converter is built in. Quote Link to comment Share on other sites More sharing options...
Syrius Posted May 15, 2005 Report Share Posted May 15, 2005 Or use HI-MD Renderer to convert not only to Wav, but OGG, Flac, and Lame MP3. Quote Link to comment Share on other sites More sharing options...
