Does the RM-MC40ELK remote have a tuner?
I was just wondering, does this remote have a buitlk in tuner?
I want to get it for my NH600D, but i wanna make sure it does beforehand...
thnx in advance..
tuner remotes (like the one that comes with the NH800) only work for players that have a 'tuner' as one of their features so the NH800 only, putting a tuner remote on a NH600D will just give you the remote functons, but not the tuner...
IMHO, the Rm-mc40elk is a bit of overkill for a NH600D, as it really shines in (stealth) recording situations, which you won't be experiencing with a download model only...
greetings, Volta
hey i found it on ebay for like $1.26, wouldnn't you jump at that oppurtunity!?
that isn't an opportunity, that's a steal... but I would really make sure the seller's legit (well, not really necessary for such a low price) cause normally it costs $70 and more (on e-bay)...
sorry to say this, but I really don't believe someone would sell their (working) rm-mc40elk for so little money... if you believe it, try it and let us now, you could have done the deal of the century!
greetings, Volta
I don't think it's the final price. There are 5 days left to bid... shok.gif
tongue.gif that explains it... just wait and see if the final price still is a steal then (I really think it's a bit of overkill for a NH600D though)
Volta, sorry to sound like an Uber-Nerd smartass.gif but regarding your post about putting the tuner remote in another unit, it won't even work. The remotes have two raised "notches" that prevent them from even going into another unit's remote jack. And believe me, I have tried.
so lemme get this straight.....I wont be able to use this remote?
- you will be able to use the RM-MC40ELK (3line remote,NO tuner, ships with NH1 mostly, costs about $70 and is a bit too specialised IMHO for use with a download-only model, as it really shows its use in stealth recording situations...but it's your money, so you are free to do what you want)
- you won't be able to use any tuner-remotes (like RM-MC39LT shipped with the NH800) as they have a different plug type
hope this helps, for further info read Yamagatacamille's guide to MD-remotes
greetings, Volta
*edit: added some color to answer darkangels next question...again
Edited by The Low Volta
  • 4 months later...
:lol: no need to be mean :o You CAN NOT use a remote that is a radio remote with any unit that doesnt have the specific radio PORT. So, for your 600 himd you can NOT use radio remotes.
ooh ooh
my turn to be a smartass :D
lol
i have a radio remote that works for my 600D
the tuner doesnt work of course
but it does fit in my 600D and has the basic functions
it was made for a normal minidisc player though
its the RM-MZ1T
ooh ooh
lol
its the RM-MZ1T
I can confirm that. I have the 37LT and the 39LT tuner remotes. They work to control my older units but you really have to jam the remote plug into the port on the MD unit. I would be afraid that using it would cause damage in the long run. Plus the screen does not even work. For the 600D I would recomend the 33EL, 35EL or 40ELK remotes (I own both the 33EL and 40ELK). With the later being the best suited for it. The tuner remotes are only really designed to work with the G750, NF610 and NHF800. I have the NF610 and NHF800.
Edited by KrazyIvan
