MDCF's SonicStage cannot remove Mp3 codec
dsb2
Connect in minidisc.org's sonicstage 3.2 has been removed, this is very good. It can save you a lot of time, but it include a new mp3 codec which can not be un-installed from control panel. this is too bad.
So, think about this first, if you really do not need this, just uncheck this when do installation.
Hi! the quality of my MP3 files copied to mi HI-MD have DECREASED since I installed 3.2 Now that I know about that MP3 codec you talk about, I know the reason. What is the exact filename of the codec, and how can I restore my old one?
My Winamp plays my MP3 files perfectly; but in SonicStage and the Hi-MD they sound worse, with "clack"-like sounds from the compression; It must be the new codec.
  • 1 month later...
You can download the installer here, install it then you'll find an uninstaller
http://f23.aaa.livedoor.jp/~kanetuki/dlcou...count.cgi?f=1_5
I can't see how is this happening, did you change the mpg123dsf config?
I didn't touch it at all >.<
Now I don't like to listen to my music at all with that poor compression. How can I restore the old codec? Any idea?
