SilverBlade Posted April 8, 2006 Report Share Posted April 8, 2006 (edited) I am going to be purchasing a car stereo with a USB port to listen to mp3s while driving. I was originally going to purchase a 1 gig USB drive to use with it, but another thought occured to me: I can use a Hi-MD player as a USB reader.Some things I'd like to know:1) Is this a good idea? 2) Do I need to install any software for Windows to detect the Hi-MD unit as a removable drive? If I do, then my idea won't really work3) Would this require batteries? or would the USB be able to power the unit while being used as a data drive?This would be a lot better (to me) because of the cost of Hi-MD media vs cost of flash drives. Edited April 8, 2006 by SilverBlade Quote Link to comment Share on other sites More sharing options...
Sony_Fan Posted April 8, 2006 Report Share Posted April 8, 2006 I am going to be purchasing a car stereo with a USB port to listen to mp3s while driving. I was originally going to purchase a 1 gig USB drive to use with it, but another thought occured to me: I can use a Hi-MD player as a USB reader.Some things I'd like to know:1) Is this a good idea? 2) Do I need to install any software for Windows to detect the Hi-MD unit as a removable drive? If I do, then my idea won't really work3) Would this require batteries? or would the USB be able to power the unit while being used as a data drive?This would be a lot better (to me) because of the cost of Hi-MD media vs cost of flash drives.If you have SonicStage 3.4 installed, Windows will recognize your Hi-MD player and it will see it as a removable drive. The problem now is, whether your car stereo will recoginize your Hi-MD unit. Quote Link to comment Share on other sites More sharing options...
ZosoIV Posted April 9, 2006 Report Share Posted April 9, 2006 It should work, as long as you format the disc as FAT32 and simply drop your MP3's onto it via Windows Explorer and not SonicStage. Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted April 10, 2006 Report Share Posted April 10, 2006 (edited) It might or it might notI tryed it as a USB drive with my brothers PS2 but It didn't work!I doubt it would work!And it might be a bit slow on reading large mp3's for playing them back...I woulden't do it! Edited April 11, 2006 by danielbb90 Quote Link to comment Share on other sites More sharing options...
