where can i find 4 track minidisc's
DJ Ren
i have a mdm-x4 mkII multitrack minidisc recorder and it is made for 4 track minidisc
but the minidisc i have bought from wal-mart(thinkin they were 4 track) were only 2 track minidisc. i have called all the music sellin store i would think would have them but ive had no luck.
can someone tell me where i can find 4 track minidisc's
thanks
thanks
and does this mean that the data disc only has 37 minutes?
data disc
Yep that's right. I have owned a yamaha 4-track md recorder in the past (excellent unit), and they are the md-data discs that give you MD Data disc, which records 8 tracks for 18 minutes or 4 tracks for 37 minutes .... i had to sell for financial reasons, otherwise i would never have let it go !
So try searching for md-data discs on the net. I found some a few months ago whilst browsing MD equipment, here are a few links:
http://www.tapeplus.com/blank-disks-md-data-minidiscs.html
http://www.minidisc-canada.com/shopdisplay...t=Data+MiniDisc
Both sites have them in stock ..... hope this helps.
CHEERS !
Edited by burns3016
