ILoveMinidisc Posted October 5, 2006 Report Share Posted October 5, 2006 I dont like the New Sonicstage version (for me they slow, and i get confused with the Album sorthing thing)Where can i download Sonicstage 2.2 or 2.3what is best of this 2 versions (give lessest problems and is fastest)for use with Sony Mz-n910 net md. Quote Link to comment Share on other sites More sharing options...
Richard Posted October 5, 2006 Report Share Posted October 5, 2006 I think you'll find 2.3 to be considerably slower than 3.x or 4.0. As far as I know 2.x is no longer officially available for download unless you have a cd yourself?* Moved to Software Discussion Quote Link to comment Share on other sites More sharing options...
Stuge Posted October 5, 2006 Report Share Posted October 5, 2006 I dont like the New Sonicstage version (for me they slow, and i get confused with the Album sorthing thing) what is your system spec ? Quote Link to comment Share on other sites More sharing options...
ILoveMinidisc Posted October 5, 2006 Author Report Share Posted October 5, 2006 (edited) what is your system spec ?I have a Xp.the biggest problem with 3.3 and even 4 is:1. If i drag a Folder into the Playlistthen when folder is created only one song apearso i have to drag rest of songs one by one2. is VERY slow to drag each song into the playlisttake like 5 minuts each.3. I get so confused between Playlist and dynamic playlistWhere am i suposed to drag the musicfor example say i have A folder with an albumand want it quick on a Md.Do i drag folder to: Playlist, dynamic playlist, album ... where?Also i want it so i can EDIT the songs in sonicstagebefore songs are transfered to Mds.Any help is apreciated,thanks in advance Edited October 5, 2006 by ILoveMinidisc Quote Link to comment Share on other sites More sharing options...
ILoveMinidisc Posted October 5, 2006 Author Report Share Posted October 5, 2006 The thing is 2.3 was the one i was most happy withi just cant realy like the 3 but then again i dont have Hi-mdand all i do is transfer the songs.I want it simple and 2.3 is for me just thatalso i feel there is more copyright restriction on versions 3where some songs wont transfer etc...(yea i know about the 3 tracks limit on 2.3 but there is ways around it)If anyone does have 2.3 on a cd i would be realy happy if they could upload it Quote Link to comment Share on other sites More sharing options...
Richard Posted October 5, 2006 Report Share Posted October 5, 2006 Have you tried version 4.0? There are certainly no DRM restrictions from versions 3.4 onwards. Quote Link to comment Share on other sites More sharing options...
ILoveMinidisc Posted October 5, 2006 Author Report Share Posted October 5, 2006 Have you tried version 4.0? There are certainly no DRM restrictions from versions 3.4 onwards.Yea i am stugling with it nowi had problem transfering some songsprogram said "song not registred with sonicstage" or something like thatand problem now i cant go back to 3.4 either , dont have the 3.4 Full version (link here on forum wont work)So i am totaly without Sonicstage.if i had 2.3 atleast i could make it run prober again.Also i tried 3.3 But each time i draged a Map with songs into sonicstageit crashed so got rid of 3.3, then installed 4 (without uninstalling 3.3)and when i run 4 program just Closes by itself.I guess i will need 2 programs to try now:Sonicstage 3.4 Full Sonicstage 2.3 full Quote Link to comment Share on other sites More sharing options...
ILoveMinidisc Posted October 6, 2006 Author Report Share Posted October 6, 2006 (edited) I solved the problems after almost 12 hours of scratching my head, installations, and reboots.the problem sonicstage 3.4 being slow is not the software is having a database being too bigi just removed the whole database and made a new one, and now it run like a thunderbird Still it takes me a lot of time to get used to the 3x sonicstage systemThis is how i upload Albums:1. I drag a Album folder to dynamic playlist2. It apear in the Album folder3. I moved this to a new created folder in playlist(i like to have all albums there)Is this the Correct way?Problem is that sometimes not all songswill show in the auto-create-album in sonicstageprobaly the Id tag on mp3 that it relies on?Anyway i am glad the Speed is back to normal.but i still wont mind go back to 2.3 , I realy like that version Edited October 6, 2006 by ILoveMinidisc Quote Link to comment Share on other sites More sharing options...
Christopher Posted October 6, 2006 Report Share Posted October 6, 2006 Let's talk about your system specs and so on for a moment. This will tickle some people when I ask this, but please state your specs according to the FAQ. You said you had XP, but what service pack? How many processes are running on your computer when you ctrl + alt + delete? Quote Link to comment Share on other sites More sharing options...
