TRA277 Posted December 30, 2006 Report Share Posted December 30, 2006 (edited) Ok so I'm old fashioned. Really old fashioned. But I like it that way.I once had a cassette multi track: adding effects whilst recording was a cinch. Then I bought this truly wonderful MD8. But when it comes to this 'effects' part, can I understand the manual? Consequently, effect(s) has to be added at mixdown, which as you can imagine, kind of limits the end sound. I mean, only one effect can be applied....Mind you, I subsequently achieve a good dry sound, no fear of echo-swamp here. But I would like someone to translate the part of this manual, the 'Adding Effects While recording' into a more user-friendlylangauge.Can anyone help me? Edited December 30, 2006 by TRA277 Quote Link to comment Share on other sites More sharing options...
mrjohnworby Posted August 18, 2007 Report Share Posted August 18, 2007 Ok so I'm old fashioned. Really old fashioned. But I like it that way.I once had a cassette multi track: adding effects whilst recording was a cinch. Then I bought this truly wonderful MD8. But when it comes to this 'effects' part, can I understand the manual? Consequently, effect(s) has to be added at mixdown, which as you can imagine, kind of limits the end sound. I mean, only one effect can be applied....Mind you, I subsequently achieve a good dry sound, no fear of echo-swamp here. But I would like someone to translate the part of this manual, the 'Adding Effects While recording' into a more user-friendlylangauge.Can anyone help me?Use aux 1 or 2 send & return the effect through inputs 9, 10, 11 or 12. You can balance the dry/wet sound with the 9 t 12 volume pots. Quote Link to comment Share on other sites More sharing options...
