vercoquin Posted January 23, 2007 Report Share Posted January 23, 2007 yesterday i received from japan the MZ-RH1 model.first thing i tried is to transfer via USB on Pc my SP live recordings i did with a netMD.SS did work fine.today i tried again with other SP live recordings and it doesnt work.i tried also with the MD i used yesterday succesfully, same, doesnt work.the HiMD is connected well i think, cause SS recognizes it and the tracks into the MD.i select the track, clicking on the arrow nothing happens, no advert no window nothing.i've SS 4.2HELP!!!!---fabio Quote Link to comment Share on other sites More sharing options...
A440 Posted January 23, 2007 Report Share Posted January 23, 2007 Since it's brand new I suggest you just uninstall and reinstall SonicStage--either 4.2 or the disc with the unit (3.4 ?)But FIRST run the Backup Tool if there's anything in My Library, just in case. Also think about the usual culprits for this: antivirus and firewall software. But maybe there was just something a little off in the 4.2 installation. Quote Link to comment Share on other sites More sharing options...
vercoquin Posted January 24, 2007 Author Report Share Posted January 24, 2007 Since it's brand new I suggest you just uninstall and reinstall SonicStage--either 4.2 or the disc with the unit (3.4 ?)i did that but nothing changed.1 hour ago i tried to put into my cd-drive the cd-rom that comes with the unit (i did not try before because when i bought 4 years ago the MZ-N10 from japan, the software was only japanese) and, surprise, the cd got sonic stage not just in english but in my language too.i installed it (4.4) and now Hi-MD works fine!!!! gosh, it was scaried.bestsfabio Quote Link to comment Share on other sites More sharing options...
