1GB disc vs 80min disc
Sony_Fan
Is there any difference in sound quality between music stored on the 1gb disc and those stored on the 80min discs (assume it's Hi-MD format)? I can't help but think that something must have been sacrificed in order to fit so much music on a 1GB disc, even though it's the same size as the standard 80min discs. Sound quality maybe?
Bits are bits - as long as the player is able to retrieve the data off the discs within the limits of error correction, there will be no impact on sound quality. When things go bad with digital, you get a signal with glitches and pops and noise, not lower subjective quality (like something being less "crisp" or what have you).
Borat, I don't know about you, but my batteries last longer when I use 1GB discs, because it is being accessed less often and spins at a lower rpm. So I try to use my 1GB discs as much as possible.
lol, pata
Edited by Sparda
Technically yes, but in a related issue there are slight audible differences between grades and brands of CD-Rs used which seem to imply that error correction and hence interpolation play a much bigger role in transports so I'd be tempted to say there might possibly be a minute difference between normal MDs and Hi-MDs, not that I have done proper comparisons between the two.
Really? I've yet to see one properly conducted double-blind test between CD-R blanks - the vast majority of differences people claim to hear are probably imagined. For Hi-MD to sound different than MD discs due to error correction would imply that one or the other gives back a lot of faulty/spurious data, which I also have seen no evidence for. When error correction steps in, it's a nasty thing - not a subtle one. I once had a badly burnt CD where it was obvious that error correction was being called upon, and there were dropouts and pops on loud peaks. But it's not like the vocals or cymbals sounded less "warm" or "crisp" or anything that would imply a difference in subjective quality.
Exactly. Digital is digital, 0s and 1s. Either you hear the music, or not (blips, skips, pops, etc).
I have read a few myth based facts before, e.g.
"My buffering CD player plays back disc X better because it has lower Jitter" - The buffer removes the jitter from the digital data so you just debunked your own reason.
"The sound is clearer from disc X" - As long as there are no read errors then digital is digital and there will be no difference, this has also been debunked by feeding the digital stream through a PC to do a CRC check on the 2 discs digital audio stream, both had the same CRC's yet people swore blind they can tell the difference.
Technically there will be no difference between audio stored on a 1GB disc and the same audio stored on an 80M disc. Now, there may be a difference between them audiably because of drive motor noise on the battery voltage etc but if the digital signal is fed to a seperate digital decode & amp it will sound the same.
