zzzuppp Posted July 27, 2007 Report Share Posted July 27, 2007 I have a Sony MZ-RH1 which I've used succesfully up- and down-loading sound on my old G4 Mac (OSX 10.3.9).Recently I bought a new iMac,2.16 GHz Intel Core 2 Duo,running OSX 10.4.10.When I connected the RH1 to it today,the HiMD Music Transfer box said 'Device not connected'.I tried rebooting,made sure I had HiMD configured on the MD in the machine,tried different MDs,different USB ports,different USB leads,disconnected/reconnected etc etc-nada,zilch,same message again and again.I checked System Profile and that could see my RH1 in the USB port,so it seems to be simply that HiMD Transfer can't 'see' my RH1 .Any suggestions? Is it an Intel Mac thing? a 10.4.10 thing?I could put all my files onto a separate HD,carry it over to the G4 and do it there,but I'd prefer it to work on the iMac. Quote Link to comment Share on other sites More sharing options...
Strungup Posted July 27, 2007 Report Share Posted July 27, 2007 are you using Version 2 of MD transfer? Quote Link to comment Share on other sites More sharing options...
zzzuppp Posted July 27, 2007 Author Report Share Posted July 27, 2007 Yes,and I've fixed it,by trashing the Sony files and reinstalling them.Phew. Quote Link to comment Share on other sites More sharing options...
Strungup Posted July 27, 2007 Report Share Posted July 27, 2007 Sometimes the install doesnt register completely , and yes reinstall is needed , I think that was even mentioned on SOny's site somewhere ,under know isssues. Quote Link to comment Share on other sites More sharing options...
marc-hd Posted July 27, 2007 Report Share Posted July 27, 2007 Hi, i'm on a Macbook intel core 2 duo and i don't have any problems with my mz-rh1. I have the MD transfer version 2 and works just fine. So it's not an intel mac problem. I hope u can solve the problemMarc Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted July 27, 2007 Report Share Posted July 27, 2007 *topic moved to "Software Discussion/FAQ's." Quote Link to comment Share on other sites More sharing options...
