Panasonic RP-HJE70
freebird2003
they also mention that the phone sounds good after "burn-in". what does that means ?? plz advise.
:unsure:
An excerpt from Head-Fi:
What is ‘burn in’?
When speaking of headphones, ‘burn in’ is the term used for the settling oft he design parameters of the diaphragms into their intended state. The physical process is that the diaphragms loosen up through use and eventually reach a point that could be considered final. A similar situation is breaking in a new pair of shoes."
Read further: Head-Fi's Headphone 'Burn In' FAQ
They look very classy & hightech for earbuds.
AudioCubes has 4 or 5 very favourable reviews for them.
Some mention that they are an improvement over the MDR-EX71
http://www.audiocubes.com/product_info.php...7e247395c4fdd14
Guest Stuge
Many People suggest that that EX71 has distroted bass,Undefined mid & Highs etcetc ...Sure no surprise that these are better .
more pics
Practicality in the form of functionality just doesn't cut it anymore when it comes to marketing consumer electronics, especially current generation of portable audio players with growing disposition as fashion accessories. Along with the influx of tastefully designed portable audio and video players came a growing demand for equally eye pleasing earphones. No doubt there already exists many beautifully styled earphones, most are average at best in audio quality. Among the few exceptions however, is the Panasonic RP-HJE70 stereo ear-bud headphones.
Build quality is the first thing you'll notice about the RP-HJE70. Contributing to this in no small way is the finely machined aluminum housing, which also suggests that it will stand up well to careless handling and will likely last the cause. Due to its brushed finishing, the RP-HJE70 has a discreet appearance and hence should go well with any audio players you own and attire you have on.
Fashion Inclined
Despite its subtle design attributes, Panasonic wants you to know that the RP-HJE70 is every bit a wearable item of fashion as other accessories in your possession. This is achieved through a simple yet imaginative design of using rubber strips and grooves located on the aluminum housing of both headphones. When gently squeezed together in the correct orientation, the rubber strip and groove on either side of the headphones will connect the two headphones together, allowing users to wear the RP-HJE70 as a necklace without the headphones dangling around in an unsightly fashion.
Carefully Conceived
Since the RP-HJE70 is a stereo ear-bud headphones, audio is expectedly much more isolated than traditional earphones.
And just to let you know that Panasonic has really given much thought to the RP-HJE70, two additional pairs of ear-buds of different sizes have been bundled in just so the headphones could comfortably fit any user. Yet, even with its metal body and additional rubber strips, the RP-HJE70 is not in any way as heavy as its external form may suggest. On the contrary, it is light, weighing just 14g.
The soft rubbery ear-buds do a commendable job in shutting out ambient noise for maximum audio enjoyment. While obviously not in the same league as in-ear headphones where reduction of ambient noise is concerned, the RP-HJE70 will be impressive enough to convince you to make the switch from regular earphones to in-ear headphones.
On The Practical Side
It's also practical too, particularly for those with players that came with a wired remote control that permits 3rd party earphones/headphones to be used. Instead of having a lengthy cord running continuously from end to end, the RP-HJE70 was designed such that it can be conveniently shortened or lengthened to suit your specific needs or player, made possible via a detachable-cord design.
Final Thoughts
Most impressive about the RP-HJE70 is the clean sound it produces. There were no traces of piercing timbre previously experienced on a number of Panasonic earphones, and while overall quality tends to veer towards the warm side, there were ample tonal definition and punchy bass for decent acoustic response. For this, its build quality and an aluminum protective case, the asking price of US$120 is not unreasonable at all. Put it this way, if you care about audio quality as much as how a product complements your image, the Panasonic RP-HJE70 has all the right boxes checked.
Product Specifications
  • In-ear Headphones
  • Frequency reponse: 10 - 23,000Hz
  • Impedance: 16ohm
  • Length of cord: 0.5m
  • 3.5mm Stereo mini-jack (24k gold plated)
  • Weight: 14g
Source:
www.hardwarezone.com.sg
Damage & LowVolta have excellent reviews on Panasonic HJE50s in the minidisc forums.
http://forums.minidisc.org/index.php?showtopic=10384
These HJE70s look like they could address some of the build problems of the E50s. However I usually find that the area with most problems is where the cords join the earphones and jack.
Edited by bogon07
Guest Stuge
i was about to buy hje70, but now sony is about to release ex90. now i don't know which to to buy and should i wait for ex90 ? haha
First of all don`t get confused ..if you want a earphone right now then you should go with HJE70 as Ex90 will be released on May 10 in Japan.
  • 1 year later...
