MD Remote Compatibility
azanshin
Very good question. I have sort of the opposite problem to you. I have an MZ-R50 that never had its own remote, and which I ended up using the modern RM-MC38EL (for MZRH1 and other units) which you can buy lots of at $10 a pop. I got rid of my stick-nonLCD remote for the NH700 and I know it works with most remotes, though the radio RM-MC37LT is the preferred one.
So all in all the answer is "probably". The only obvious thing that doesn't work right on the R50 with the modern 38EL remote is the pause/play/jog lever. It plays and goes forward and back, but pushing as if to "pause" simply restarts the current track. The display looks fine.
Hope this helps
Stephen
Hope this helps
Stephen
Thanks man. Am going to take the plunge and purchase it
