casiokorg Posted January 30, 2013 Report Share Posted January 30, 2013 I love my MXD-D3. making minidisc's on it is amazing. But one aspect that it seems to struggle with is copying CDr's. has anyone else noticed this? it seems to play some better than others. does anyone have any ways around this? also does anyone recommend anything for making discs on this unit? maybe some better settings etc etc. thanks! Here's my current setup. NOTE: the speakers are from the Sony MJ-L1. found one in a thrift store in LA a few years back for $40. it was half working, fixed the cd player part but then the minidisc part never really worked. kept the speaker though! Quote Link to comment Share on other sites More sharing options...
zahne Posted February 12, 2013 Report Share Posted February 12, 2013 Hi there. If you mean copying CDrs to MD, I've found good results with staples CDs. They're cheap and pretty reliable. I've been able to do high speed copying from CDrs to MD with it. Nice looking set up btw! Quote Link to comment Share on other sites More sharing options...
oroville Posted March 22, 2013 Report Share Posted March 22, 2013 I used ones made by tdk and my deck reads them perfect i burned a flac file and cue sheet to a cdr it worked perfect when dubbing to md even on the fast setting. Quote Link to comment Share on other sites More sharing options...
THIS SUCKS Posted March 22, 2013 Report Share Posted March 22, 2013 try burning the cdr at 4x instead of max speed. i always had better luck that way. Quote Link to comment Share on other sites More sharing options...
