Octaedre Posted May 6, 2013 Report Share Posted May 6, 2013 Hello ! I have just registered to this forum because I have recently gotten hold of a MD recorder, an MZ-N10, which I've got from a friend who had not used it in years, and who apparently did not plan to. The thing is, the unit won't read any MDs. Whenever I try an MD inside it, it fiddles around for a while making a loud whirring sound, eventually ending out with a "Read Error" alert. At first I thought it was just a problem with the MD but as I have another recorder that works, as I tested more and more MDs out it became apparent the problem came from the unit. Firstly I downloaded the manual off the internet and tried the "reboot" method that basically instructs to power down everything, let it rest for a while then power it back up, to no avail. Then I learned there was a service mode for the device, so I downloaded the service manual. After launching the service mode (with one of the methods that doesn't require you to disassemble the whole thing) and out of curiosity, I ran the self-diagnosis result display mode, to try to learn more about what could've caused the issue. This returned : 013 1 00B6 004 N 004B 035 N100B6 004 N200B6 000 R_004B Now I'm a complete noob when it comes to this kind of things, and I don't know if this would help, but the error codes indicate : a TOC address data error (013, which I have no idea what it is), two spindle errors indicating an abnormal rotation of disc (both 004 errors) and a MD DATA 2 disc error (the 035 one, which again, I have no idea what it might be). Have any of you had this problem before ? Is it repairable with having to send it back to Sony ? Thanks in advance ! All the best, A. Quote Link to comment Share on other sites More sharing options...
jim.hoggarth Posted May 7, 2013 Report Share Posted May 7, 2013 Read errors are usually a result of a bad optical pickup unit, but that said a flaky spindle motor will also cause distress. The motor in the N10 rarely fails, but it is not unheard of. I certainly think you are not going to effect a repair without experience and parts. The good news is that the R_004B figure means the unit has barely been used, certainly as a recorder. So the optical pickup should be like new. It may also mean the internal battery is in A1 condition, which is a rarity for this model. You may well have a machine very much worth repairing. If you need a repair, PM me or email on jim.hoggarth@blueyonder.co.uk. I am in the UK, so postage to me is not too expensive. Jim Quote Link to comment Share on other sites More sharing options...
Octaedre Posted May 7, 2013 Author Report Share Posted May 7, 2013 Apparently he did not use it much, he got a digital recorder shortly after and I think this has stayed in a box for quite a while. The unit looks really good too, apart from a dent on the outside of the rotary controller thingy (which may indicate that it was dropped ?). I'm usually not that afraid to take things apart for repair or do a bit of soldering, but I usually work on much bigger hardware, mostly old game consoles, so I'm not too comfortable with disassembling something that small, especially since I have absolutely no experience with MDs (it's only the second MD player I get, and I'm new to the format so). Thanks a lot for the quick answer! I'll get back to you soon Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted May 7, 2013 Report Share Posted May 7, 2013 Octaedre, je te recommande chaudement Jim. J'ai deux unités (RH1, NH900) chez lui en ce moment. Quote Link to comment Share on other sites More sharing options...
Octaedre Posted May 7, 2013 Author Report Share Posted May 7, 2013 Octaedre, je te recommande chaudement Jim. J'ai deux unités (RH1, NH900) chez lui en ce moment. Ah cool, merci ! Je ne savais pas qu'il y avait des français sur le forum, c'est marrant Quote Link to comment Share on other sites More sharing options...
jim.hoggarth Posted May 7, 2013 Report Share Posted May 7, 2013 Et je parle francais un peu aussi, mais pas tres bien! Jim Quote Link to comment Share on other sites More sharing options...
Octaedre Posted May 7, 2013 Author Report Share Posted May 7, 2013 Don't worry I'll most likely keep talking in english anyway haha. I don't own a lot of Sony hardware but I'm only just getting into MDs so, who knows... Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted May 8, 2013 Report Share Posted May 8, 2013 jonathanpotato est aussi français, sinon depuis la disparition du forum français (hacké puis abandonné) MDCF en France, on s'est rabattu sur LaserdiscPlaza Quote Link to comment Share on other sites More sharing options...
